Earth/ground points
SOOOOOOOOOOOOO any one got any idea where the earths on a 306 for the dash area other than the one behind the pedals?
Fairly sure my phs1 s16 had one behind the panel under the drivers side dash, kind of too the right of the peddles
Passenger side footwell on the Left hand side big ass bolt all you got to do is scrape some paint off if there is any just pull the carpet back a little
had a thought earlier, have you checked the big plug in the bulkhead on the drivers side? it has all the electronics from the engine to the dials/gauges
radio earth wire?
(29-05-2013, 07:08 PM)swampy Wrote: Fairly sure my phs1 s16 had one behind the panel under the drivers side dash, kind of too the right of the peddles
Ill check that out later cheers
(30-05-2013, 12:41 AM)ozonehostile Wrote: had a thought earlier, have you checked the big plug in the bulkhead on the drivers side? it has all the electronics from the engine to the dials/gauges
Good point zak. Im going on the theory its an earth fault atm. I will take that plug out next.
Do the speakers have an earth point?
[Image: mcetg0.png]
(30-05-2013, 10:59 AM)lolsteve Wrote: Do the speakers have an earth point?
Not a separate one, they're earthed through the headunit.
  Earth locations pug306driver 2 3,976 22-01-2022, 04:19 PM
Last Post: pug306driver
Rainbow Gearbox earth connection part FIXED Welshy_Pete 7 6,113 22-05-2016, 06:29 PM
Last Post: P-Courty
  l/h/side earth point pug306driver 2 2,842 15-02-2016, 06:16 PM
