Threads: 35
(1.9 dturbo) My rev counter does not working so would like to know where it gets its feed from I.e gearbox, alternator or from the tdc sensor. Also I will check the plug going to the cluster see if it has come loose tomorrow but everything else on there works.
NO SMOKE NO POKE
Threads: 35
Ok so I've been told it gets its feed from the tdc sensor. Should the engine stop if I unplug it and the sensor is working. I've just unplugged mine with the engine running and it didn't effect it at all
NO SMOKE NO POKE
Threads: 87
48
it's a white plug on the gearbox iirc mate . . unplug, clean and plug back in . .
Threads: 71
Car Model/Spec: Diablo Dturbo S
I have the same problem aaron! Bump!
Threads: 16
Car Model/Spec: Phase 3 DTurbo
What colour plug does that lead connector plug into mate? My counter isnt working also..
Threads: 71
30-05-2013, 05:21 PM
(This post was last modified: 30-05-2013, 05:23 PM by scottbmxer.)
Mine works when I first start the car and then after like 5 or so mins when its warm it stops working! If you have a similar problem to me its prob because it needs cleaning
Sorry just read u replaced the part! Was it not working at all before? Did it just die all of a sudden and never come bac on?
Threads: 42
Car Model/Spec: Ph1 black d turbo
Hi, I didn't have a rev counter on my 96 xud for 2 years then I recently did a gearbox change and found the sensor was unscrewed under the block.
I just knocked it back in, slightly touching the fly wheel and put a new screw in and it's worked fine since. Drive shaft might have to come off for access though.
Threads: 35
Anyone had any luck yet. Just noticed this in my old threads and mine is still not working but tbh I haven't used the car since November. Ha. It still doesn't work though because I start it regularly and want to get it back on the road now and thought I might as well have another crack at this while I'm sorting other things.
NO SMOKE NO POKE
Threads: 177
It will be the sensor gap. jack the car up and leave it running, pull the sensor most of the way out and slowly tap it back in while getting someone to watch for then the rev counter starts working
