25-03-2013, 02:37 PM
		Hi  All
I have an oil leak i have a few ideas of what it could be but would like some advice. Thanks
					Oil Leak
		Hi  All I have an oil leak i have a few ideas of what it could be but would like some advice. Thanks
		almost as bad as my oil leak! yours looks to be comming down the front of the block is it power steering fluid,rocker cover,eek head gasket may even be a sump gasket
		25-03-2013, 03:55 PM
		Always look at the highest point first mate clean it all off and keep an eye on it. More than likely the rocker gasket
		25-03-2013, 03:59 PM
		Pictures can be helpful... that one isnt.  As said, work from top down, writing off possibles as you go! Wishes for more power... (25-03-2013, 03:55 PM)Puggie Wrote: Always look at the highest point first mate clean it all off and keep an eye on it. More than likely the rocker gasket Ok Thanks. (25-03-2013, 03:59 PM)Piggy Wrote: Pictures can be helpful... Lol. Ok (25-03-2013, 03:30 PM)cully Wrote: almost as bad as my oil leak! Nt Sure yet going to have a closer look tomoz.
		26-03-2013, 11:39 AM
		Found the problem it was the Rocker Cover Gasket .
		26-03-2013, 11:44 AM
		Bingo.   15 min job bud including the cuppa
		26-03-2013, 04:28 PM
		Make sure you do it with original peugeot parts as the cheap flea bay patent parts dont seal properly! Trust me ive been through a few of these until i got it right! The ebay ones are really hard rubber and the pug ones are actualmrubber if that makes sense    (26-03-2013, 04:28 PM)k3ogh Wrote: Make sure you do it with original peugeot parts as the cheap flea bay patent parts dont seal properly! Trust me ive been through a few of these until i got it right! The ebay ones are really hard rubber and the pug ones are actualmrubber if that makes sense Hey Nearly all of the parts i get are gen pug parts but thanks anyway.
		26-03-2013, 11:35 PM
		i had the exact same problem and repair haha, funny how one little tear in the gasket lost me so much oil
		27-03-2013, 10:52 AM
		27-03-2013, 01:40 PM
		myne wasnt ripped or any thing it just wasnt mating with the surface properly, and be sure to torque it up evenly, i have a haynes here if you need the settings?
		27-03-2013, 01:59 PM
		Torque your rocker bolts down to 5nm bud
	 (27-03-2013, 01:59 PM)Puggie Wrote: Torque your rocker bolts down to 5nm bud Ok thanks (27-03-2013, 01:40 PM)k3ogh Wrote: myne wasnt ripped or any thing it just wasnt mating with the surface properly, and be sure to torque it up evenly, i have a haynes here if you need the settings? I Have got a haynes but thanks anyway.
		16nm for a rocker cover wow bit much innit autodata says 5nm ? i would go with autodata every time
		27-03-2013, 06:01 PM
		just goin of what haynes say never had any problems with there settings dude
		28-03-2013, 07:00 PM
		5NM?  I don't think I've even seen a torque wrench go that low lol!
		Wow the advice on here spot on if you ain't seen a torque wrench that goes that low i suggest you stop buying shit tools autodata 3.40 is the latest version and that's what it says guess it must be wrong eh ? And before someone says they know better prove me wrong ?
		28-03-2013, 09:59 PM
		torque screwdriver ; also keep an eye on that leak if it comes back, as the headgasket oil feed hole is common to leaking in the o/s/f corner and leaks out and down the front of the block. |
