Threads: 376
38
Car Model/Spec: Phase 1 GTI 6
22-02-2013, 06:29 PM
(This post was last modified: 19-07-2013, 09:56 AM by ginge191 .)
So i need cooling for the 205, i was looking at bonnet lining, but had a look at a 205 and 306 lining and both seem to be, well, 'meh' is about all i can say, so need alternative cooling...
I was looking at using a SMIC for the setup, found one from a pajero and thought in total, it has about the same cooling capacity as a TMIC, yes it's deeper, but our's are wider.
I've got a couple of pics, any sort of photoshops would be awesome, as subtle as possible please
all attempts repped!
http://sphotos-g.ak.fbcdn.net/hphotos-ak...6088_n.jpg
http://media.fastcar.co.uk/wp-content/up...1.6_11.jpg
Phaes 1 GTI 6 - Onyx Black
Threads: 150
14
Car Model/Spec: 306 HDI
22-02-2013, 06:34 PM
(This post was last modified: 22-02-2013, 06:34 PM by declantg .)
Massive FMIC?
306 HDI, soon to be XUD
Threads: 198
135
Threads: 448
51
Threads: 198
135
You could even try the old desk fan approach?
Or failing that, stop being cheap and go for one of these.
A Zoom for the hamster that lives in your engine bay
/trolololol
are you thinking simple scooby scoop??
Threads: 376
38
22-02-2013, 08:18 PM
(This post was last modified: 22-02-2013, 08:19 PM by ginge191 .)
do you know what spellowe - i almost, (but i deleted it) saying "nothing too gash/chavvy <<<spellowe"
I knew you were going to do this
but do love them
(22-02-2013, 07:14 PM) Piggy1987 Wrote: are you thinking simple scooby scoop??
but yeh, something quite simple; there loads on ebay, not HUGE scooby scoops..
Threads: 27
20
How's about 2 of em in the middle
Threads: 376
38
i did think about this but not sure how it would look at all... but yep, it is an option!
or a mitsi evo type bonnet...? cut outs?
Threads: 376
38
(22-02-2013, 10:52 PM) Piggy1987 Wrote: or a mitsi evo type bonnet...? cut outs?
Unfortunately the evo vents havn't got a lot of direction for air flow, and would (i assume) just flow a breeze, i'm after a bit more of a shot onto the intercooler
Threads: 96
Just cut the bonnet with a grinder down two sidesaddle a across like an outline of the tmic then bend the bonnet backwards so air flows directly onto the intercooler and mesh the gap so no stones etc smash it ???
Threads: 61
Given 6 thank(s) in 5 post(s)
(23-02-2013, 10:31 AM) Jukie88 Wrote: Just cut the bonnet with a grinder down two sidesaddle a across like an outline of the tmic then bend the bonnet backwards so air flows directly onto the intercooler and mesh the gap so no stones etc smash it ???
I think this is what I'm going to do with the spare bonnet I have until I put fmic on
23-02-2013, 10:57 AM
(This post was last modified: 23-02-2013, 10:59 AM by Piggy .)
Threads: 376
38
(23-02-2013, 10:57 AM) Piggy1987 Wrote: yeah plus bit of fibreglassand filler...job done
this any help??
http://www.ebay.co.uk/itm/subaru-impreza...3c1&_uhb=1
http://www.ebay.co.uk/itm/subaru-impreza...89f&_uhb=1
http://www.ebay.co.uk/itm/ISUZU-TROOPER-...160&_uhb=1
Yes! they're ideal - not too big, quite flat, poi-fect
Threads: 376
38
Courtest of Warlord on .net, i'm liking this a LOT!
Threads: 236
36
Looks a bit pish.
Only scoop allowed on a 205 is an original T16 jobby.
Ta-da-
Threads: 96
7
Car Model/Spec: 306 tractor
Threads: 208
60
Given 5 thank(s) in 5 post(s)
Just do what they have done with the matt black sedan. Cut 3 sides of a rectangle and fold it down over tmic
Threads: 376
38
01-03-2013, 01:07 PM
(This post was last modified: 01-03-2013, 01:07 PM by ginge191 .)
As awesome as the T16 vent is, it's fairly pointless in relation to the TMIC
(01-03-2013, 12:34 PM) puglove Wrote: Just do what they have done with the matt black sedan. Cut 3 sides of a rectangle and fold it down over tmic
Not a bad shout TBH
Threads: 208
60
Somthing like this, simple ,cheap, works & dosnt make you look like a barryboy
Image(s)
Threads: 376
38
(02-03-2013, 08:38 PM) puglove Wrote: Somthing like this, simple ,cheap, works & dosnt make you look like a barryboy
That is perfect! where is this from?!
Threads: 208
60
its that SonnyRoby guy from romainia
Threads: 376
38
Ah ok, i might pm him about it, see how/where he got it from
Threads: 208
60
IIRC he go it from his angle grinde
think its just a tidy hole cut in the bonnet, i wouldnt cut the back edge though and fold it down to direct the wind back at the IC though. then a bit of that U shspped rubber trim around the edges
Threads: 130
82
Car Model/Spec: 106 GO-NAD
Thing with that, is that its not actually going to get any significant amount of airflow through it, and thwres nothing directing it in. It'll work a bit, but the major of the air will just skip over the top
Threads: 208
60
Nah you dont know what your talking about lol
Threads: 130
82
Nah, I do a bit
Threads: 208
60
May be a little . Bit if you stick your hand out the window and flap it about abit that will direct tye air into the hole. Gigity.
(thats hand out the window not cock)
Threads: 376
38
Ok, so i'm reviving this with a slightly different title.
I'm noticing BAD heat soak and related boosting issues with the lack of cooling to the TMIC.
Possibly a bonnet lining would suffice? but would prefer an alternative; i know the scoops are an option; a grinder and a vent isn't too hard to install, but visually a bit gash.
I understand that a couple of mist jets could be of use also; but how much do they/can they actually cool the TMIC.
Any other ideas would be awesome!
