Bleeding brakes 306 hdi abs
Hello I've changed some brake pipes on my 306 hdi with abs. So I need to bleed them in this order?
osr, nsr, osf and nsf
thanks
The advice I was given was start at the furthest away and end at the closest to the master cylinder so on mine it would be nsr/osr/nsf/osf
(13-02-2013, 10:46 AM)Willo Wrote: The advice I was given was start at the furthest away and end at the closest to the master cylinder so on mine it would be nsr/osr/nsf/osf
Correct. I duno if it really makes that much diffenece tbh. Just make sure you dont run out of fluid while bleeding it through
All done now like new now thanks
  Bleeding Brakes With Peugeot Planet Tom85 3 3,462 22-06-2017, 08:08 PM
Last Post: Tom85
  Help with brake bleeding Iaitoo 18 8,082 10-06-2016, 06:06 PM
Last Post: Poodle
  Bleeding abs pump. bashbarnard 14 8,853 24-05-2015, 06:48 PM
Last Post: Toms306
