05-02-2013, 12:25 AM
		Hi everyone ;
- First of all I apologize for my bad English, but believe me it is not very easy,
make the effort reciprocal.
- If someone wanted to help and take raduire my document I would see no
objection.
- Feel free to debate and discuss an international perspective, ;-) !!
* * * Optimizations,Part 1 * * *
- - - For optimized the XUD9TE : We can... - - -
- Switch ON / OFF for the alternator load = economy some HP motor in turning.
- Switch ON / OFF for cooling fans forced march, prevents overheating.
- Refresh the intercooler by water spray with wiper nozzles from exemple.
- Delete a max weight unnecessary because -100Kg = +10Hp.
Cutting all plastques shock absorbers behind bumpers in the trunk.
- Properly distribute the masses moving battery and tank and windshield washer
fluid in the trunk,
- Replace the original glass windows with heavy Makrolon,much lighter
(attention to safety if it is to run all day with).
- Remove the spare wheel cage in favor of a fastening system Homemade.
- Preparing a fastening system of the rear seat with butterfly metal not
plastic (to be able to remove it easily).
![[Image: ecroupapillonaoreilles7.jpg]](http://img853.imageshack.us/img853/4678/ecroupapillonaoreilles7.jpg)
![[Image: ecrous.jpg]](http://img841.imageshack.us/img841/808/ecrous.jpg)
- Replace the original steering by one electric of Saxo or 106 Phase2.
Those of Renault Clio or R19 or do the trick too.
- Changing the segmentation by the new
- The best engine assembly is:
Block XUD9TE / L Type: D8A and DHY yoke of Citroen Jumpy 1.9TD with a camshaft
of XUD atmospheric or cylinder gasoline 16S resized view by re-cutting the
pistons to lower the relative volumetric.
- We could optimize serously the perfs with addition of a cooling liquid to the
cylinder head XU or TU.
- It's possible to mount a turbo 406 T16 kind VAT25 with 2-3 modifications.
1900cm3 is 1900cm3, after the petrol or diesel engine remains the same blocks
are TU and XU petrol and diesel possible use it in any Plug & Play with some
modifications.
- It's possible to find some head pump Bosch 12mm on these vehicules :
4x4 Land Rover et Nissan Cabstar.
- Gearbox 406 HDi Estate society with Fifth gear 405 L Essence if possible
or gearbox of 306 2.0 HDi type ref 20TB51 or :
Keep the 306-405TD gearbox and just replace the bevel with a 17*59
- For the LDA : Cone LDA N°56 de 605 ou 405 TD.,N°34 court JR,
N°51 JR taillé à 13,5° Cotes Oettinger-N°72 RA-SB,N°36H VW Passat TDI 110,
N°51 (Audi 80 TDI),N°71 (VM 2,5),N°72 (Fiat),N°75 (605,Fiat),
N°75H (IVECO Daily TDI).
- For the camshaft XUD7,the Citroen Visa Diesel is Ok.
- Cut the plastic surrounding the propeller radiator before leaving almost as
fasteners and so it let the air directly to the radiator for better cooling
water.
- Replace original camshaft XUD9TE by a camshaft Sharper atmospheric XUD9 or XUD7.
- Add Modine oil cooler of 205 GTI 1.9 on the XUD9TE,Opening with thermostat at
80°C,85°C.
- Mounting gasket reinforced and polishing the yoke.
- Thermally insulating the exhaust manifold and all elements of turbos in amount
of a sheath air intake mounted in the car forced to direct cool air to the
elements that heat.
- Replace the cooling system of the D8A by these of DHY phase2 more better and
more efficient.
- Replace the exhaust line for 2.1TD than XUD11 with one Silent 306S16 GrN or
any line échapement for XUD9T must be optimized with a minimum diameter of 63mm with ultimately a silencer stainless steel of at least 85mm and 110-115mm max.
- Increase the oil pressure hose and mount aviation oil circuit
- Make up more fluid fuel with supplementary heaters, and magnets for descaling
gasoil to energize the metal components in the fuel optimizing combustion.
The principle is called " SFI ",do not buy it, build it or have it manufactured.
It's called a SFI box in France, here's a test in French of a product POWER
SYSTEM,some friends use that but no sold,realized full home made.
http://www.automotoconso.com/leblog/?p=542
- Creating a micro leak turbo regulation with a valve millimeter and a pressure
in the vacuum exhaust manifold.
- Mounting Engine mounts 306 HDi + support distribution side gearbox of 306 HDi
on the TD.
- Radiator cap water Xsara TD than 306 or ZX TD
- Rear axle Xsara VTS
- Master cylinder HDi Break 406 + Front brakes 406 HDi HDi estate or 206-307
Berlingo HDi society.
- Mounting T3 of Lancia Thema Turbo T16 with Wastegate Renault Clio Dci
- It's possible to install the oil cooler anywhere with the installation
a radiator-type cooling Spal above, then mount a switch handler ON/Off on the
circuit probe T°C oil for managed the oil T°C.
- Make a hole or holes in the wheel wells to increase the flow
cooling air into the engine: make cuts in the right places
knowing that water, mud and gravel pass through the holes
cuts unless they stick or fix any fawn grid or other
something of the same kind.
- Intercooler Renault Scénic DCi et DTi,Renault 21 TD or Ford Focus TD,
BMW 525 TDS,806 2.0TCT
- Cone LDA Ref:H Alfa Romeo
- The engine XUD9TE is also mounted in these cars:
Citroen BX,ZX,Xantia,Xsara,Berlingo,Jumpy,Jumper,Talbot Horizon,FSO Caro,,,
Peugeot 205,405,309,306,Partner
Also on Volvo 440TD, LDV Pilot, Rover 218 and Rover 418, Fiat Scudo,Suzuki vitara.
FIAT Ducato and former ROVER 200 series
- Injectors Mercedes 300D and injectors 330D are OK,or Injectors Renault Espace
2.1TD Phase2 1995-1996
- Adapting a radiator water of 405TD or Xantia 2.1
- The mounting gearbox 307 HDi 136Hp perhaps with some interesting
mods.
- Mounting on Lower engine 2.1TD XUD11 on the block 1.9TD XUD9
- Adapting a flywheel 206HDi
- Fuel Pump for 2.1TD XUD11 prepared with head pump Iveco.
- 2.5TDi Fiat Ducato Turbo engine Sofim (big mods)
- Xantia 2.1 HDi Gearbox (longer)
- Booster pump fuel 205 GTi forced to pump fuel of 306TD, better fuel flow
- Semi polishing and polishing not complete the intake manifold (turbulence
required,disturbances of the air flow required)
- Flywheel lightened up the original 2O6 Hdi if too much loss of speed
max unless big turbo.
- Increasing the size of the fuel hoses for example those XUD11 2.1 TD
or any other size than the original ones for better flow diesel.
- It's possible to mount a part of the line of the ESC C2 1.4HDi for better
perfs or those of an Opel Kadett Essence not gasoil.
- Installation of fuel pump diesel 2.8 TD PSA XUD9TE is possible.
- Mounts fixed rear aluminum to remove the effect self-Directional
sometimes dangerous circumstances Racing.
- Intercooler 525 tds,806 2.0TCT for FMIC.
- GT2052 VNT hybrid Land Rover TD5 mountable XUD9TE, as the area
Phase2 2.1TD 1995/96, GT2052-56, TD2052 and Fiat Croma 2.0TDid 1989.
- It's possible to find a Head Pump Bosch 12mm findable on Peugeot Boxer
2.8TD trucks.
- It's possible to find a diesel pump heads in 11mm on 4x4 Nissan Terrano
2.7TD Engine TD27TIOHV.
- Exhaust 406 63mm
- Remove the fuel filter to filter the fuel condition manually first,it
facilitates the flow of fuel flow and at the same time.
- The air box has 206 1.4 to 2.0 HDi are perfect for optimized 306 TD.
- For machined cones LDA must 100C6 type of metal eg
- Nozzles 299a, 299s, 299c's Update 2000.
- Rods 306HDi monted on the 306TD
* * * Optimizations,Part 2 * * *
- To mount Peugeot strengthened triangles, there are triangles
306S16 for identical triangles 306HDi.These references triangles
are Ref: 3520.K0 and 3520.G0 normally solded 700€ the pair.
- To strengthen the original front triangles, simply mount
silentblocs Ref Peugeot: 3523.83, triangles Partner, Berlingo
Xsara and original elements have strengthened but are less wide
about 20mm than 306 flares front hubs + channels to compensate for
the missing 20mm.
- These elements are very close to the technical characteristics of
parts or type PTS Racing-Competition.
We have a site in France where prices are very interesting pieces
and some parts are of excellent quality: http://www.oscaro.com/
- Torsion bars Xsara VTS 167hp rear are 21mm original
and those GTi6 306S16-HDi Xs and 20mm are original.
- After installing big brakes on the front, why not adapt front
brakes original S16, TD HDi or another PSA on the rear of 306.
- Beams crossings rear PSA yellow are strengthened,some are black
but also difficult to identified among normals.
- Fit a limited slip differential set at 40% with box speed and shafts.
- Installation of a front sway bar 22mm.
- To optimize fresh air into the engine it may be useful to cast an
air intake Renault Clio Clio 16S or William's on above the engine
(discretion guaranteed)
- Installation of 2 front fenders, hood and tailgate rear fiber composite
for optimal weight gain.
- Whatever the size in inches, try to mount magnesium rims.
- For weight gain, cut the interior door fitting is performed and
plexiglass plate in fine or Makrolon or other like this.
- Remove carpets as soundproofing in engine compartment, under the
hood then you can cut pieces of inner body to gain more weight on
the scale (remember -100Kg = +10 Hp)
- The rear seat weighs just 30kg about it
- The gimbals 306 Gti-6 with ABS are of larger diameter than with TD,
16V,XSI, and Hdi (check)
- Remove the rubber on the pulley Damper origin for weight gain because
it serves as shock absorber and vibration of the crankshaft then to
stop the transfer of heat to the belt.
This rubber is also not up accoup the compressor air conditioning in
crankshaft and other accessories the re-sending compression.
Il is primarily used for startup and shutdown of the engine.
- Remove the complete air removal of ABS + full
- Installation of a proportioning valve
- Add one electric water pump in the cooling circuit.
- It is possible to mount a radiator to cool the motocross turbo.
- In order to stiffen the rear as the 206 RC is enough Half-mounting
the rear arm 206 Break and on the support system the beam as well as
the tie origin.
- The brake master cylinder may be a PSA 23.8mm Plug & Play
- Do not forget to put the right fuel in your tank types Premium Excellium
the best quality summary.
- You can use a liquid additive to your coolant to reduce T°C
engine as a whole, so more perfs.
This is the "Red Line Waterwetter" other similar products on the market.
You also offer your tricks if you want,international Tips LoL !!
objection.
fluid in the trunk,
modifications.
water.
80°C,85°C.
elements that heat.
more efficient.
on the TD.
mods.
2.8TD trucks.
- Exhaust 406 63mm
the missing 20mm.
the tie origin.
![[Image: 20A1806D-891D-40FB-BD52-AD519177A607-734...391753.jpg]](http://i35.photobucket.com/albums/d196/mattbush/20A1806D-891D-40FB-BD52-AD519177A607-7340-0000058F46391753.jpg)
	![[Image: 2conomisateurmagntiqued.jpg]](http://imageshack.us/scaled/thumb/195/2conomisateurmagntiqued.jpg)
![[Image: anneauantitartrepourmac.jpg]](http://imageshack.us/scaled/thumb/845/anneauantitartrepourmac.jpg)
![[Image: economiseurcarburant2.jpg]](http://imageshack.us/scaled/thumb/841/economiseurcarburant2.jpg)
![[Image: principeduboitiersfi.jpg]](http://imageshack.us/scaled/thumb/402/principeduboitiersfi.jpg)
![[Image: schmas1.png]](http://imageshack.us/scaled/thumb/811/schmas1.png)
![[Image: 2j1o9li.jpg]](http://imageshack.us/scaled/thumb/809/2j1o9li.jpg)
![[Image: 69535285.jpg]](http://imageshack.us/scaled/thumb/594/69535285.jpg)
![[Image: 411ok.jpg]](http://imageshack.us/scaled/thumb/197/411ok.jpg)
![[Image: 510md.jpg]](http://imageshack.us/scaled/thumb/96/510md.jpg)
![[Image: coneldan72modifioetting.jpg]](http://imageshack.us/scaled/thumb/805/coneldan72modifioetting.jpg)
![[Image: dscn2908e.jpg]](http://imageshack.us/scaled/thumb/94/dscn2908e.jpg)
![[Image: lda19tdpompebosch.jpg]](http://imageshack.us/scaled/thumb/32/lda19tdpompebosch.jpg)
![[Image: yatp8.jpg]](http://imageshack.us/scaled/thumb/822/yatp8.jpg)
![[Image: tigepompegasoilbosch19t.jpg]](http://imageshack.us/scaled/thumb/90/tigepompegasoilbosch19t.jpg)
![[Image: smog105411479.jpg]](http://imageshack.us/scaled/thumb/6/smog105411479.jpg)
![[Image: schmakitldapowersystemp.jpg]](http://imageshack.us/scaled/thumb/526/schmakitldapowersystemp.jpg)
![[Image: n34courtjrn51jrtaill135.jpg]](http://imageshack.us/scaled/thumb/19/n34courtjrn51jrtaill135.jpg)
![[Image: lda1300tdi.jpg]](http://imageshack.us/scaled/thumb/259/lda1300tdi.jpg)
![[Image: lda36hgaucheet71droite3.jpg]](http://imageshack.us/scaled/thumb/812/lda36hgaucheet71droite3.jpg)
![[Image: fonctionnementinternede.jpg]](http://imageshack.us/scaled/thumb/443/fonctionnementinternede.jpg)
![[Image: cn6sc.jpg]](http://imageshack.us/scaled/thumb/26/cn6sc.jpg)
![[Image: eclatboschvesp21td12vxu.jpg]](http://imageshack.us/scaled/thumb/835/eclatboschvesp21td12vxu.jpg)
![[Image: eclatdepiepicpour21tdps.jpg]](http://imageshack.us/scaled/thumb/20/eclatdepiepicpour21tdps.jpg)
![[Image: pilectrovannerotodiesel.jpg]](http://imageshack.us/scaled/thumb/43/pilectrovannerotodiesel.jpg)
![[Image: pompey.jpg]](http://imageshack.us/scaled/thumb/267/pompey.jpg)
![[Image: schemapiboschlectrovann.jpg]](http://imageshack.us/scaled/thumb/109/schemapiboschlectrovann.jpg)
![[Image: ve170.jpg]](http://imageshack.us/scaled/thumb/39/ve170.jpg)
![[Image: ve171.jpg]](http://imageshack.us/scaled/thumb/713/ve171.jpg)
![[Image: ve174.jpg]](http://imageshack.us/scaled/thumb/843/ve174.jpg)
![[Image: ve175.jpg]](http://imageshack.us/scaled/thumb/39/ve175.jpg)
![[Image: ve180.jpg]](http://imageshack.us/scaled/thumb/694/ve180.jpg)
![[Image: ve181.jpg]](http://imageshack.us/scaled/thumb/560/ve181.jpg)
![[Image: veblowup.jpg]](http://imageshack.us/scaled/thumb/543/veblowup.jpg)
![[Image: veldakit.jpg]](http://imageshack.us/scaled/thumb/577/veldakit.jpg)
![[Image: vemainkit.jpg]](http://imageshack.us/scaled/thumb/853/vemainkit.jpg)
![[Image: xud11lucas.gif]](http://imageshack.us/scaled/thumb/171/xud11lucas.gif)
![[Image: zxxud919dkitbiogasoil.jpg]](http://imageshack.us/scaled/thumb/836/zxxud919dkitbiogasoil.jpg)
![[Image: xud11turbolucasphz.gif]](http://imageshack.us/scaled/thumb/16/xud11turbolucasphz.gif)
![[Image: xud11turboboschphz.gif]](http://imageshack.us/scaled/thumb/541/xud11turboboschphz.gif)
![[Image: xud11turbobosch.gif]](http://imageshack.us/scaled/thumb/191/xud11turbobosch.gif)
![[Image: post11079080050.jpg]](http://imageshack.us/scaled/thumb/801/post11079080050.jpg)
![[Image: post11079082166.jpg]](http://imageshack.us/scaled/thumb/541/post11079082166.jpg)
![[Image: projectt25.jpg]](http://imageshack.us/scaled/thumb/845/projectt25.jpg)
![[Image: t3360npdr.jpg]](http://imageshack.us/scaled/thumb/689/t3360npdr.jpg)
![[Image: t25turbomanifoldforgt20.jpg]](http://imageshack.us/scaled/thumb/855/t25turbomanifoldforgt20.jpg)
![[Image: touslesmodlesturboskkk.jpg]](http://imageshack.us/scaled/thumb/809/touslesmodlesturboskkk.jpg)
![[Image: turbineetaxederouesurtu.jpg]](http://imageshack.us/scaled/thumb/19/turbineetaxederouesurtu.jpg)
![[Image: kkkkit.jpg]](http://imageshack.us/scaled/thumb/715/kkkkit.jpg)
![[Image: gtkitdrawing.jpg]](http://imageshack.us/scaled/thumb/820/gtkitdrawing.jpg)
![[Image: fonctionnementturbogomt.jpg]](http://imageshack.us/scaled/thumb/845/fonctionnementturbogomt.jpg)
![[Image: eclattb02.jpg]](http://imageshack.us/scaled/thumb/46/eclattb02.jpg)
![[Image: eclatt2t25t28tb02tb25tb.jpg]](http://imageshack.us/scaled/thumb/4/eclatt2t25t28tb02tb25tb.jpg)
![[Image: arpourlesturbos.jpg]](http://imageshack.us/scaled/thumb/855/arpourlesturbos.jpg)
![[Image: eclatvnt25outd2502decro.png]](http://imageshack.us/scaled/thumb/255/eclatvnt25outd2502decro.png)
![[Image: unejante.jpg]](http://imageshack.us/scaled/modthumb/571/unejante.jpg)
![[Image: corrrespondancepneusjan.jpg]](http://imageshack.us/scaled/modthumb/189/corrrespondancepneusjan.jpg)
![[Image: infoscarrossageetgeomet.jpg]](http://imageshack.us/scaled/modthumb/94/infoscarrossageetgeomet.jpg)
![[Image: janteet2nt.gif]](http://imageshack.us/scaled/modthumb/27/janteet2nt.gif)
![[Image: unejante.gif]](http://imageshack.us/scaled/modthumb/833/unejante.gif)
![[Image: entraxejantesparmarques.jpg]](http://imageshack.us/scaled/modthumb/818/entraxejantesparmarques.jpg)
![[Image: tableaudesindicesdechar.jpg]](http://imageshack.us/scaled/modthumb/23/tableaudesindicesdechar.jpg)
![[Image: aiguillesinjos19tdpsaco.jpg]](http://imageshack.us/scaled/modthumb/28/aiguillesinjos19tdpsaco.jpg)
![[Image: boschdn0sd293.jpg]](http://imageshack.us/scaled/modthumb/803/boschdn0sd293.jpg)
![[Image: schmainjecteurcommonrai.jpg]](http://imageshack.us/scaled/modthumb/546/schmainjecteurcommonrai.jpg)
![[Image: injecteurstdi.jpg]](http://imageshack.us/scaled/modthumb/39/injecteurstdi.jpg)
![[Image: diamtresetinfosvism5m36.png]](http://imageshack.us/scaled/thumb/703/diamtresetinfosvism5m36.png)
![[Image: 9ypzm.jpg]](http://imageshack.us/scaled/thumb/19/9ypzm.jpg)
![[Image: acav1l10.jpg]](http://imageshack.us/scaled/thumb/502/acav1l10.jpg)
![[Image: carterhuilexud11td12vps.jpg]](http://imageshack.us/scaled/thumb/805/carterhuilexud11td12vps.jpg)
![[Image: commonrailhdipsa.jpg]](http://imageshack.us/scaled/thumb/213/commonrailhdipsa.jpg)
![[Image: dw10ated4.jpg]](http://imageshack.us/scaled/thumb/200/dw10ated4.jpg)
![[Image: dw12td4.jpg]](http://imageshack.us/scaled/thumb/521/dw12td4.jpg)
![[Image: schmasupportrouedesecou.jpg]](http://imageshack.us/scaled/thumb/571/schmasupportrouedesecou.jpg)
![[Image: moteurxud9te.jpg]](http://imageshack.us/scaled/thumb/5/moteurxud9te.jpg)
![[Image: modlestypesminesetautre.jpg]](http://imageshack.us/scaled/thumb/717/modlestypesminesetautre.jpg)
![[Image: lqz8e.jpg]](http://imageshack.us/scaled/thumb/11/lqz8e.jpg)
![[Image: elementscompletsmoteurx.jpg]](http://imageshack.us/scaled/thumb/571/elementscompletsmoteurx.jpg)
![[Image: eclatsupportmoteurbote.jpg]](http://imageshack.us/scaled/thumb/841/eclatsupportmoteurbote.jpg)
![[Image: eclatdemitrainavant306.jpg]](http://imageshack.us/scaled/thumb/687/eclatdemitrainavant306.jpg)
![[Image: tkxpz.jpg]](http://imageshack.us/scaled/thumb/442/tkxpz.jpg)
![[Image: cablagepourswap205tct.jpg]](http://imageshack.us/scaled/medium/502/cablagepourswap205tct.jpg)
![[Image: cablagepourswap205tct2.png]](http://imageshack.us/scaled/medium/607/cablagepourswap205tct2.png)
![[Image: egr1.jpg]](http://imageshack.us/scaled/medium/198/egr1.jpg)
![[Image: apportairfraisintercool.jpg]](http://imageshack.us/scaled/medium/580/apportairfraisintercool.jpg)
![[Image: 2conenonexcentriquesurb.jpg]](http://imageshack.us/scaled/thumb/707/2conenonexcentriquesurb.jpg)
![[Image: 4conenonexcentriquesurb.jpg]](http://imageshack.us/scaled/thumb/194/4conenonexcentriquesurb.jpg)
![[Image: pin13het75hdroite.jpg]](http://imageshack.us/scaled/thumb/685/pin13het75hdroite.jpg)
![[Image: ldas.jpg]](http://imageshack.us/scaled/thumb/203/ldas.jpg)
![[Image: eclatboschve.jpg]](http://imageshack.us/scaled/thumb/577/eclatboschve.jpg)
![[Image: modificationducapotlda.jpg]](http://imageshack.us/scaled/medium/703/modificationducapotlda.jpg)
![[Image: tournerlamembranedelda.png]](http://imageshack.us/scaled/thumb/252/tournerlamembranedelda.png)
![[Image: 1marquedoigtpalpeur.jpg]](http://imageshack.us/scaled/thumb/593/1marquedoigtpalpeur.jpg)
![[Image: 2marquedoigtpalpeur.jpg]](http://imageshack.us/scaled/thumb/18/2marquedoigtpalpeur.jpg)
![[Image: 1rondelleblanche.jpg]](http://imageshack.us/scaled/thumb/845/1rondelleblanche.jpg)
![[Image: 3rondelleblanche.jpg]](http://imageshack.us/scaled/thumb/201/3rondelleblanche.jpg)
![[Image: 2rondelleblanche.jpg]](http://imageshack.us/scaled/thumb/717/2rondelleblanche.jpg)
![[Image: visdesurchargecroucrnel.jpg]](http://imageshack.us/scaled/thumb/401/visdesurchargecroucrnel.jpg)
![[Image: axedugouverneur.jpg]](http://imageshack.us/scaled/thumb/11/axedugouverneur.jpg)
![[Image: visdedbitdegasoil1.jpg]](http://imageshack.us/scaled/thumb/442/visdedbitdegasoil1.jpg)
![[Image: visdedbitdegasoil2.jpg]](http://imageshack.us/scaled/thumb/802/visdedbitdegasoil2.jpg)
![[Image: visderglageduralenti.jpg]](http://imageshack.us/scaled/thumb/194/visderglageduralenti.jpg)
![[Image: rglagecableaccelerateur.jpg]](http://imageshack.us/scaled/thumb/405/rglagecableaccelerateur.jpg)
![[Image: acclrateurrgimemaxi.jpg]](http://imageshack.us/scaled/thumb/839/acclrateurrgimemaxi.jpg)
![[Image: ressortldamodif.png]](http://imageshack.us/scaled/thumb/16/ressortldamodif.png)
![[Image: ressortlda.png]](http://imageshack.us/scaled/thumb/703/ressortlda.png)
![[Image: ressortcalorstat20511l.jpg]](http://imageshack.us/scaled/medium/6/ressortcalorstat20511l.jpg)
![[Image: intercoolerspal.jpg]](http://imageshack.us/scaled/thumb/198/intercoolerspal.jpg)
![[Image: intercooleraireau1.jpg]](http://imageshack.us/scaled/thumb/705/intercooleraireau1.jpg)
![[Image: intercooleraireau2.jpg]](http://imageshack.us/scaled/thumb/838/intercooleraireau2.jpg)
![[Image: preintercooler.jpg]](http://imageshack.us/scaled/modthumb/39/preintercooler.jpg)
![[Image: hybridver445ve420.jpg]](http://imageshack.us/scaled/thumb/855/hybridver445ve420.jpg)
![[Image: hybridver445ve41.jpg]](http://imageshack.us/scaled/thumb/546/hybridver445ve41.jpg)
![[Image: hybridver445ve42.jpg]](http://imageshack.us/scaled/thumb/831/hybridver445ve42.jpg)
![[Image: hybridver445ve43.jpg]](http://imageshack.us/scaled/thumb/820/hybridver445ve43.jpg)
![[Image: hybridver445ve44.jpg]](http://imageshack.us/scaled/thumb/90/hybridver445ve44.jpg)
![[Image: hybridver445ve45.jpg]](http://imageshack.us/scaled/thumb/834/hybridver445ve45.jpg)
![[Image: hybridver445ve46.jpg]](http://imageshack.us/scaled/thumb/17/hybridver445ve46.jpg)
![[Image: hybridver445ve47.jpg]](http://imageshack.us/scaled/thumb/703/hybridver445ve47.jpg)
![[Image: hybridver445ve48.jpg]](http://imageshack.us/scaled/thumb/836/hybridver445ve48.jpg)
![[Image: hybridver445ve49.jpg]](http://imageshack.us/scaled/thumb/267/hybridver445ve49.jpg)
![[Image: hybridver445ve410.jpg]](http://imageshack.us/scaled/thumb/541/hybridver445ve410.jpg)
![[Image: hybridver445ve411.jpg]](http://imageshack.us/scaled/thumb/715/hybridver445ve411.jpg)
![[Image: hybridver445ve412.jpg]](http://imageshack.us/scaled/thumb/829/hybridver445ve412.jpg)
![[Image: hybridver445ve414.jpg]](http://imageshack.us/scaled/thumb/20/hybridver445ve414.jpg)
![[Image: hybridver445ve415.jpg]](http://imageshack.us/scaled/thumb/571/hybridver445ve415.jpg)
![[Image: hybridver445ve416.jpg]](http://imageshack.us/scaled/thumb/560/hybridver445ve416.jpg)
![[Image: hybridver445ve417.jpg]](http://imageshack.us/scaled/thumb/688/hybridver445ve417.jpg)
![[Image: hybridver445ve418.jpg]](http://imageshack.us/scaled/thumb/145/hybridver445ve418.jpg)
![[Image: hybridver445ve419.jpg]](http://imageshack.us/scaled/thumb/541/hybridver445ve419.jpg)
