Threads: 541
124
I have a low entry jack and dont have that problem (apart from with the BMW)
Actually, theres another one.......
When you cant get a low entry jack under your car.
Threads: 25
Car Model/Spec: dturbo
when mot men cant get your 306 onto the mobile ramp in a car park at like 1 oclock in the morning ...lol!
Threads: 541
124
When the AA cant get your car on their flatbed.
Threads: 28
Car Model/Spec: Anything but a 306
You own a VW and cut 5 coils out of the front spring.
Or you fit your space saver and the front bumper sits on the floor.
Threads: 541
124
When you get a puncture and the sills hit the floor and grind you to a stop.
(27-01-2013, 10:08 PM)Norledge Wrote: You own a VW and cut 5 coils out of the front spring. Thats german over engineering for you, I dont think our front springs have 5 coils.
Tuck is the new poke y0!
Threads: 163
53
Car Model/Spec: 406 HDI
(27-01-2013, 10:18 PM)Dum-Dum Wrote: When you get a puncture and the sills hit the floor and grind you to a stop.
They couldn't even be arsed putting coils on the back...
Threads: 170
(27-01-2013, 08:20 PM)RePT Wrote: (27-01-2013, 06:54 PM)karl1989 Wrote: when you have to drive onto a stone or wood to get a jack under neath
when you can hear your plowing snow
Smart! Ill put that into practice.
Usually i would pull the T-jack out the boot(or whatever its called), jack it up a little with that then the big jack!
would take me an hour getting it back in its place.the T jack that is. i have a block of wood in the boot just incase
Venetian XUD ph2 heaven
Ph3 perv cab heaven
Black ph1 XUD died
Moonstone hdi stage 2
Threads: 208
60
When you have to use the OE jack ti jack it up abit before getting you troll jack in to jack it up
Man that pisses me off
Threads: 143
10
Car Model/Spec: Ph3 XUD
For me a couple days ago it was Brick>OE jack>trolley jack.
Threads: 448
51
When you crack to sumps under normal driving.
When moting the cant check the brakes on there rollers as the car ends up beached.
When the mot tester can't get it on the four poster
When you've scraped a 6inch hole in the lashup demidbox.
All personal achievements
Threads: 94
When people ask you to stop the car to get sick because the bouncing of 3 nicks is just that fun
Threads: 61
Car Model/Spec: 306 DT GLX '98
When your on that m6 bridge where your tires make a racket!
Threads: 183
20
Always drive it onto wood.
Used to have a certain part of my drive where it was just right.
But 20 years of my dad, stepdad and me abusing my drive wheh working on cars it collapsed on me last time!
Threads: 92
43
People call you Irish
Threads: 183
20
Your lard arse sister has to get out the car so you can pull on drive without ripping something off.
Threads: 29
Your car will not go on the drive, you cannot have anyone sat in the back, and you ripped the fuel line and assorted parts off the bottom of your car by driving over a manhole.
Threads: 73
6
Car Model/Spec: Shitbox Polo 1.0
(01-02-2013, 09:27 PM)kentiiboii Wrote: Used to have a certain part of my drive where it was just right.
I used to have an inspection pit in my front garden which was pretty handy with my old Rover. It wasn't an actual inspection pit as such it was like the council had just loosely concreted a bit of our driveway in the middle but the sides were top notch so a mate of mine borrowed a mini digger from his work and dug the centre section out, bottom was concreted and then the sides were skimmed 4 times with concrete...about 3 or 4 days work but the inspection pit is still there to this day!
Member of Team Rather be Gay than Ginger
Member of Team Holey Engine
Threads: 183
20
(04-02-2013, 02:57 AM)InkedMuttley Wrote: (01-02-2013, 09:27 PM)kentiiboii Wrote: Used to have a certain part of my drive where it was just right.
My uncle built his own garage and also built a inspection pit. That's where all the work to my car gets done now. He's old so he can't get use out of it.
Threads: 208
60
When your sills ground out on all the speed ramps trying to get into the RR meet
Threads: 130
82
Car Model/Spec: 106 GO-NAD
When the grand total of your suspension travel is the give in the bumpstops
