Xud fitment
Xud fitment
I know the xud was used in a few cars but what besides peugeots are they fitted in
Suzuki Vitara, Ducato van? old Rover I think. Quite a few more.
GT2052s DTurbo
OEM+ HDI Estate
Project thread
think they were in an ldv van too
Edit: LDV pilot
There's a list on here:
http://en.wikipedia.org/wiki/PSA_XUD
GT2052s DTurbo
OEM+ HDI Estate
Project thread
citroen bx, zx, berlingo, c15, xantia, xsara, visa
peugeot 306, 405, 309, 205, 305, 406, expert, partner
small ldv vans, old toyota corrolas, fiat ulysee, rover 200,400, talbot horizon.
suzuki vitara, baleno and some lada
the 2.1 xud came in peugeot 406, 605, 806, 807, citroen xm
there was a xud derivitive in peugeot 106, citroen ax and rover metro
(27-01-2013, 12:03 AM)ozonehostile Wrote: there was a xud derivitive in peugeot 106, citroen ax and rover metro
Completely different engine; TUD5 non-turbo diesel. Early ones were 1.4 and alloy block, later ones were 1.5 and iron block Wink
Thanks guys wonder if any of them are cheaper to buy a Bosch pump for hmmmm
they were based on the petrol xuj engine wernt they? just modified for diesel, tud i belive?
They weren't based around anything I don't think, just TU fitment. XU is the taller range of petrol engines like GTi6's (XU10J4RS), 205 GTi's (XU7/9) etc
(27-01-2013, 12:24 AM)Willo Wrote: Thanks guys wonder if any of them are cheaper to buy a Bosch pump for hmmmm
check rovers for bosch pumps, the lda pin in bosch pumps on rover engines has a better shape curve.
just ask around your local scrappys/breakers about bosch pump prices, prices depend on if they know what there worth or not, you could be lucky if your local is clueless and pick up a pump with all the lines and injectors for £30
Is it the old shape rover 200 not the bubble shaped ones
Also how do I tell if its a Lucas of a Bosch by looking at them ???
bosh has the "ufo" shape cap with the lda pin inside, lucas pumps have no distinguishing features, just looks like a bunch of pipes going into a block
This is a Lucas ay it ?
[Image: 70F50399-01BF-431B-9990-4D13C3F7B659-181...95B9DA.jpg]
pictures from ash23 old project
lucas pump
http://i779.photobucket.com/albums/yy74/...fff013.jpg
bosch pump
http://i779.photobucket.com/albums/yy74/...161508.jpg
Got ya sound thank you mate much appreciated
if your resorting to scrapyards for a bosch, peugeot 405's are the best to check for bosch pumps as it seems the overwhelmingt majority of 306's in scrappys are phase 2 with lucas units
But make sure it's not a semi-ECU type if it's in a 406. They're quite obvious though.
Ok I'll keep me eye out when I'm next at the scrappy not something I'm desperate for just on the to get list
Just to say, the TUD4 and 5 that are in 106s / Saxon/ axs are based on the TU petrol engines. The TUD5 is the same block as the TU6 gti engine, just with a different head and stroke and pistons obviously. Completely unrelated the the XU series.
The XUD was also fitted to some TATA 4x4 iirc
Samass is right about the TUD4 and TUD5 they are based on the TU petrol lumps
Just like the XUD is based on the XU petrol engines.
People also often get very confused about NA Lucas pumps, people assume that ALL Bosch VE pumps have the UFO on top which is untrue...
[Image: XUD9AEngineresized.jpg]
^^ For example...
it took me a while to realize what i was looking at when i found a nad citroen at the scrappy with the topless bosch
