	Threads: 138
72 Location: Milford, Surrey
 Car Model/Spec: Mincebus
 Thanks: 0Given 0 thank(s) in 0 post(s)
		Android torque and this? http://item.mobileweb.ebay.co.uk/viewite...7906468197
Anyone heard/played with one before? Worth it or better off getting a proper one?
Astor 'X' 4 GTi6-6  - SOLD!
	Threads: 198
135 Location: Not near you
		Is your phase 5.3 GTi6 OBDII?
	Threads: 289
92 Location: London
 Car Model/Spec: Phase 17 R26
 Thanks: 0Given 1 thank(s) in 1 post(s)
		Your phone doesn't generate much torque, if any.
 /trollface
	Threads: 129
11 Thanks: 0Given 0 thank(s) in 0 post(s)
		 (10-01-2013, 08:38 PM)Scott Wrote:  Your phone doesn't generate much torque, if any.
 /trollface
More than a '6 though
Stage 2 XUD Sedan
	Threads: 138
		I'm a newb at this diagnostic shit pellowe, is it an obdll I'm after?
	Threads: 198
		GTi6's never supported OBDII fella. They use an older diagnostic system that PP2000 works with but wasn't universally compliant like OBDII. Annoying, I think multiplex Xsara VTS's WERE OBDII compliant...
 So no, you don't want one of those. Well you probably do, but it won't work very well.
 I should have kept my mouth shut and giggled at the "where does this plug in?" thread
	Threads: 581
195 Location: Bournemouth
       Thanks: 36Given 82 thank(s) in 78 post(s)
		Yes it will work. Depsite the fact that they wernt officially OBD2 compliant, the later ones do work with OBD2 readers.
 Is it worth it? Not at all. The phone apps give bugger all read outs (even the high spec ones) and will basically just give you the readings you have on the dials in front of you and fault codes (but remember not all faults generate a code so bit useless really without sensor values)
	Threads: 198
		Ahh I forgot Ed's was a phase 7
	Threads: 171
46 Location: Portsmouth
		10-01-2013, 09:05 PM
(This post was last modified: 10-01-2013, 09:09 PM by 4WayDiablo.)
		My mate with the hdi has what looks to be the exact same one in the picture and has paid the £5 or however much it was form the full app version
 It gives many readouts like the scanguage actual mpg average mpg speed and so on
 Even gives a readout of boost on his as well as a few others. I'll ask him when I next see him and get you a lil list of things that give a readout on his
	Threads: 198
		I thought the HDi's were officially OBDII compliant though, hence the ability to remap using the OBD port, and why the Magnetti Marelli 1AP ECU on the GTi6 had to be mapped with emulators and not "on the fly"?
	Threads: 171
		Ah whatever! Lol I'll shut up thenJust thought they may have been the same
	Threads: 581
		 (10-01-2013, 09:05 PM)4WayDiablo Wrote:  Not entirely true niall
Thats mainly a feature of the software its self and the fact the HDi ecu is more OBD compliant (although not fully)
Considering you dont own a 6, i fail to see how you can tell me its not true what readings you get with these cheap obd readers when ive used them my self on my own 6.
If you had a HDi, you may get a boost reading and mpg but thats about it extra.
pellowe, HDis are not officially OBD compliant although being a much more modern ECU than the 6, its more workable!
	Threads: 138
		So in short I can't monitor lambda voltage, Tps voltage, map sensor pressure, or anything worthwhile monitoring?
	Threads: 581
		 (10-01-2013, 09:17 PM)Ed Doe Wrote:  So in short I can't monitor lambda voltage, Tps voltage, map sensor pressure, or anything worthwhile monitoring?
No. Basically you just need a mate who is a f*cking top lad to lend you his PP in exchange for at least a cup of tea or two!
	Threads: 386
87 Location: Suffolk
 Thanks: 1Given 118 thank(s) in 117 post(s)
		How can a HDi ECU give you a boost reading?  Theres no boost/pressure sensor is there?  Also........how does it read mpg, if the HDi ECU could do mpg readouts then surely they could've built an mpg reader into the dash?
 Diesels didn't have to be fully OBD copliant until 2004, theres a lot of things you cant do on a HDi that you can with a newer car, even with a decent scan tool.
	Threads: 581
		 (10-01-2013, 09:20 PM)Toms306 Wrote:  How can a HDi ECU give you a boost reading?  Theres no boost/pressure sensor is there?  Also........how does it read mpg, if the HDi ECU could do mpg readouts then surely they could've built an mpg reader into the dash?
I wasnt even sure if they did do boost. that was just what 4waydildo said.
Any 306 ecu theoretically can work out mpg considering all it needs to know is distance covered and the amount of fuel/injector timings but a lot of cars back then didnt have them anyway!
Correct, there is a lot you can do with a fully compliant car but the HDi isnt bad really!
	Threads: 171
		Thats what I said and thought but it does give a boost reading and seems about rightSo just assumed it must have had a sensor or something somewhere
	Threads: 386
		Hmm, there was mpg meters even back on mk2 Golfs........  I guess fuel prices have only been an issue more recently though.  Or VAG's just better...
There isn't much you can play with on the HDi tbf, it doesn't really allow many sensor tests and stuff, but it does give a lot of useful readings (MAF, TPS, RPM etc).  There were all sorts of odd things you could do on the Golf with a decent scan tool (the snap on one at college) including proper sensor tests, extra info, clocks check (play with needles and warning lights lol)..............no idea what the clock test is for really, but it was fun to play with lol....
	Threads: 198
		Tom in another Golf related post shocker
	Threads: 386
		 (10-01-2013, 09:32 PM)cwspellowe Wrote:  Tom in another Golf related post shocker
Pfft, its a comparative of the two cars OBD capabilities, relevant to the thread.
	Threads: 138
		No. It's totally irrelevant seeing as my car is not an Hdi, I don't give a shit about mpg, and I never ever want a comparison against a golf. But thanks for playing.
You shall get many many cups of tea Niall    rest assured!!
	Threads: 198
		Pretty sure Golf GTI's were OBDII and you could probably do something with that or something.
 Golf.
	Threads: 386
		 (10-01-2013, 09:41 PM)cwspellowe Wrote:  Pretty sure Golf GTI's were OBDII and you could probably do something with that or something.
 Golf.
GTIs?  The 115bhp slow heavy shitters?  Ewwwww.....
	Threads: 581
		Tom, the reason why you could do alot more with the golfs is because they were OBD complaint for the reason that OBD2 was originally a german standard and so a lot of the manufacturers jumped on the bandwagon early.
 The HDi ecu you can do a fair bit with with PP2000 but seeing as its not fully obd complaint, you cant do it all from your basic obd reader. But anyway, youve managed to change the subject to golfs again!
 Ed, dont bother mate. I know you always think your car is broken and therefore if you like, we can arrange a lease agreement on my PP2000 and accompanying laptop.
	Threads: 138
		Hahaha! Read my mind Niall, I was going to just text you asking how much and where you got your pp from, and or if you could give me a copy for some moneys/shinies
	Threads: 581
		 (10-01-2013, 09:51 PM)Ed Doe Wrote:  Hahaha! Read my mind Niall, I was going to just text you asking how much and where you got your pp from, and or if you could give me a copy for some moneys/shinies
We will talk business when i meet you on saturday
	Threads: 138
		Do you mix business with pleasure....?
	Threads: 581
		 (10-01-2013, 09:53 PM)Ed Doe Wrote:  Do you mix business with pleasure....?
For you?
No not really.
	Threads: 138
		Sadface
	Threads: 581
		 (10-01-2013, 10:07 PM)Ed Doe Wrote:  Sadface
Oh ok, ill make an exception! (if you blow me whilst im driving your car to poodles!)
