Threads: 25
Car Model/Spec: dturbo
09-12-2012, 09:16 PM
(This post was last modified: 28-12-2012, 08:18 PM by GP123.)
I have a RHF5 IHI Turbo lying here, its off a 3.1TD Isuzu trooper jeep. Ages ago a 306 manifold was put onto it and i just came across it again. Im wondering is it worthwhile looking into again? as in would it work lol. Any help welcomed..
Edit** Picture of turbo in question..
Threads: 198
135
Looks like a Garrett T series substitute to me?
Post the serial numbers and i'll do some digging for jew
duno...........but you wana sell?
Threads: 25
i will go out now and get some numbers off it, only 15k miles on it!
Threads: 198
135
09-12-2012, 09:26 PM
(This post was last modified: 09-12-2012, 09:30 PM by cwspellowe.)
There's the compressor map fella, looks a bit on the small side to me?
Also the VJ11 i can see implies it's from a 2.0 Ford Probe.
Massively inefficient at anything over 20psi or so so wouldn't be ideal for big boost, and the flow rate isn't amazing either
Threads: 25
Turbo Spec- VIDF 0411
Serial Number- RHF5 29011R
Parts Number- 8972572000
Threads: 198
135
09-12-2012, 09:34 PM
(This post was last modified: 09-12-2012, 09:36 PM by cwspellowe.)
Ahh so that's not the one in the picture?
Also that's an RHF5 not an RHB5..
Threads: 41
Car Model/Spec: Dtractor
09-12-2012, 10:45 PM
(This post was last modified: 09-12-2012, 10:49 PM by Dave.)
Looking at that compressor map, it looks very similar to a td04 13g tbh. A 13g starts its efficiency at about 125-150cfm, and holds on until around 250ish, which again is very similar to that turbo - give it a whirl  looks like it can hold its pressure quite well too, 35psi ftw!!
Threads: 198
135
Nuh-uh Dave, the turbo's only 60% efficient at 28psi (PR=3) and 240cfm
Wouldn't like to run that at chronic boost tbh, wouldn't see much gain flow-wise over much lower psi
Threads: 25
Sorry RHF5 i meant lol.. so you think its not worthwhile putting on or making it work?
Threads: 41
Yeh but the turbo efficiency drop of 15% would definitely be outweighed by the volumetric efficiencies gained through running an extra 8psi at the manifold  hence why in reality, as soon as you bump up the boost, you make more power because these heads are certainly far from perfect and the extra boost at higher rpm's easily outweighs the losses in compressor efficiency, but yeh 35psi probably a little much  but 28 psi is definitely doable as a daily :p
Threads: 198
135
(09-12-2012, 11:14 PM)GP123 Wrote: Sorry RHF5 i meant lol.. so you think its not worthwhile putting on or making it work?
Give it a try, only way you'll ever know
Threads: 4
If this is jonnies old one I compared side by side with a few and it defo looked a good bet and near as bolt on as you can get Id stick it on and see rather than dithering over maps.
Threads: 41
(10-12-2012, 01:43 PM)con67 Wrote: If this is jonnies old one I compared side by side with a few and it defo looked a good bet and near as bolt on as you can get Id stick it on and see rather than dithering over maps.
man speaks truth
Threads: 25
Threads: 541
124
(28-12-2012, 08:17 PM)GP123 Wrote: Can anyone help me out with what i need to do here to get this to work for me?
Wastegate actuator
Oil lines
Water lines (if your gonna use it)
Boost pipes
Exhaust adaptor
Threads: 25
(28-12-2012, 08:29 PM)Dum-Dum Wrote: (28-12-2012, 08:17 PM)GP123 Wrote: Can anyone help me out with what i need to do here to get this to work for me?
Wastegate actuator
Oil lines
Boost pipes
Exhaust adaptor
Would this do my job mate?
http://www.ebay.co.uk/itm/Subaru-EJ20-EJ...53f13d555f
Threads: 25
Can i use this turbo without using the water feeds?
Threads: 198
135
Yup, a lot of people don't bother with water cooling as the oil cooling should be sufficient. Think it's the TD04's have water cooling jackets on them?
Threads: 25
(29-12-2012, 11:42 AM)cwspellowe Wrote: Yup, a lot of people don't bother with water cooling as the oil cooling should be sufficient. Think it's the TD04's have water cooling jackets on them?
Cheers mate!
Threads: 25
Nice wee picture to show the difference to be made
Threads: 25
08-01-2013, 07:48 PM
(This post was last modified: 08-01-2013, 07:49 PM by GP123.)
Well i got the kkk out the other day and took the exhaust elbow off it (as i needed it for the trooper turbo anyway) and a chewed up, well part of a propellor fell out lol.
Anyway i found out i needed a flange made for the end of the low pressure line, so wasnt so bad everything else seems to be bolting straight on!
One last question would be do i need to cover up the water line holes? Or will they be grand open? I dont plan on running water lines to it as when i get the turbo back i just want to get it on to fook and fire her up.
Don't worry about the water holes, will be good left open
Threads: 25
08-01-2013, 07:52 PM
(This post was last modified: 08-01-2013, 08:31 PM by GP123.)
Cheers mate. I had to weld the wastegate closed just as i couldnt get the actuator on at all! :/ dont think its the right one.
Just worrying cause i just have the standard tmic on. But my mate has a scania turbo in his and it goes at 2 bar no problem..
Will update either this thread or my cars thread whenever i get it on and if all works out hopefully get it put on a rolling road to see what its doing..
