09-12-2012, 10:20 PM
		That the gti-6 6 speed box fits these as I've been told it will
					Is it true
		09-12-2012, 10:22 PM
		Yes, but the ratios are far too short for normal use. Depends what you want it for... Economy, then no.
		09-12-2012, 10:25 PM
		Even with 6th gear?  Surprising!
		It's a close ration box... the 6th gear is no longer, they're just closer together
		09-12-2012, 10:26 PM
		6th at governor is about 105
Peugeot 206 GTI HDI Volvo V50 2.0d Volvo XC90 D5
		09-12-2012, 10:37 PM
		Yep, tried and tested.  And I turned the gearbox oil silver in 2000 miles, the diffs in them apparently don't like 300+lbft torque... And made the synchro on 3rd disappear... And 3700rpm ish at 70mph... And a 105mph limit at around 5300 if you're govmodded... Trust me, if you do ANY more than 10 minutes a month at 60+, you'll want rid of it. Just because they're 6 speed, they aren't any longer, they're actually shorter overall than most of the 5 speed boxes!
		09-12-2012, 11:05 PM
		Oh right thanks guys ill look out for a dtub box or hdi box near me then thanks fellas
		10-12-2012, 01:33 AM
		Or you can try a 405td box as its sposed to be a good compromise between the Hdi and 306 Dtub box
		10-12-2012, 05:19 AM
	 (10-12-2012, 01:33 AM)ash240970 Wrote: Or you can try a 405td box as its sposed to be a good compromise between the Hdi and 306 Dtub box an hdi box would defiantly be your best bet if you want good economy, ive always felt that for a big family car, i.e long distance motorway cruising etc, the 405 gear box could do with a much longer 5th, just seems to run out of puff a bit quick, always think it would be so much better with a really long 5th or a 6th gear. just a shame that 6 speed dervs didnt really exist until about 2003 so not much chance of getting a 6 speed derv box to fit an old xud
Current stable  '09 Mercedes E320cdi wagon '99 306 gti6
		10-12-2012, 05:53 AM
		I just wondered cos me old man has a ford galaxy diesel with a 6 speed box and its great at motorway speeds
		10-12-2012, 08:28 AM
		if you changed to an hydraulic clutch i'm sure the 6 speed dervs use a be3 housing. they certainly look similar
		10-12-2012, 06:09 PM
		Nothing like sadly, they're an ML series box, you'd have to adjust the subframe, bulkhead and chassis leg to fit.... And it's hydro clutch...
