Threads: 155
11
Car Model/Spec: Bianca DTurbo
Fitted the td04 at the weekend with dan! And it went really well so happy days there.
It's been boosting fine all week at over 30psi no problems but today while traveling home the turbo started loosing psi big time, it's boosts to 5 psi easy but struggles to get over 10 psi. I have a small hole on the side of the tmic where the d seal is but it shouldn't lose all that psi from there.
Has anyone for any ideas?
Threads: 198
135
Er, boost leak?
You're welcome
Threads: 155
11
Lol my small brain has just about worked out that I have a boost leak but the problem is trying to locate it. All the boost leaks iv has in the past is sudden with a massive loss of boost all at once.
Start with the d seal...go from there
Threads: 124
26
Car Model/Spec: Megane DCiR
If its got a leak it aint gona build much boost
Threads: 155
11
(05-12-2012, 11:49 PM)Piggy1987 Wrote: Start with the d seal...go from there
I would think the d seal would lose over 30 psi though.........
Threads: 87
48
(06-12-2012, 11:09 AM)Mowle5677 Wrote: (05-12-2012, 11:49 PM)Piggy1987 Wrote: Start with the d seal...go from there
i once refitted my tmic and the D seal was hanging out . . .went from 24psi down to 5-7psi . .so yeah . . . check that shit out yo . .
Threads: 155
11
06-12-2012, 11:12 AM
(This post was last modified: 06-12-2012, 11:16 AM by David.)
(06-12-2012, 08:33 AM)CJ_Derv Wrote: If its got a leak it aint gona build much boost
I know but I'm really stumped with it.
(06-12-2012, 11:11 AM)Mattcheese31 Wrote: (06-12-2012, 11:09 AM)Mowle5677 Wrote: (05-12-2012, 11:49 PM)Piggy1987 Wrote: Start with the d seal...go from there
I think I'll try and sort that out then
Threads: 376
38
Car Model/Spec: Phase 1 GTI 6
But think; if you know about a "small hole" somwhere in the intake, 30psi on your TD04 and that small hole doesn't stay small for long.
Good luck with it all
Phaes 1 GTI 6 - Onyx Black
Threads: 155
11
Anyone in Essex got a spare tmic?
Threads: 155
11
Also forgot to mention it dont smoke when I put my foot down
Threads: 87
48
(06-12-2012, 04:47 PM)Mowle5677 Wrote: Also forgot to mention it dont smoke when I put my foot down
well that's wrong . .very wrong lol . ..hmmmmmmm fcuk knows then.
Threads: 226
24
Car Model/Spec: A3 TDi
It wouldnt because theres no boost to push the lda down to give more fuel :p
Threads: 87
48
(06-12-2012, 04:49 PM)Tom Wrote: It wouldnt because theres no boost to push the lda down to give more fuel :p
narr it'd smoke like fcuk if there was a boost leak even without lda fuel . .
a d seal is pennys...get that sorted then go to next issue
Threads: 155
11
I thought it was weird as it always smokes very badly when it has a boost leak. The d seal is only 2 days old!!
Threads: 198
135
Well when you've fixed the leak you blates need more fuel then
Threads: 155
11
The fuel seems fine when it's all working fine but might turn it up a little more for fun
Threads: 41
Car Model/Spec: Dtractor
Given 6 thank(s) in 6 post(s)
A small leak can be exponential to performance, thats how turbo's work  If you loose 5psi of IMP, you'll loose more than 5+ psi of EMP, causing a huuuuge knock on effect with your performance, it will just tail off. This is where VNT's excel with their manifold pressure management too.
Threads: 155
11
(06-12-2012, 11:27 PM)Dave Wrote: A small leak can be exponential to performance, thats how turbo's work If you loose 5psi of IMP, you'll loose more than 5+ psi of EMP, causing a huuuuge knock on effect with your performance, it will just tail off. This is where VNT's excel with their manifold pressure management too.
Thanks mate
Threads: 87
48
yeah yeah yeah . . . . still doesn't explain why he's not smoking thoough . .
Threads: 155
11
It should be smoking like fcuk ATM but it ain't. I really wanna know why it ain't.
Threads: 36
18
Car Model/Spec: DT
What's the throttle arm like, getting full use of the gov'?
On the 306 waiting list.
Threads: 155
11
Hang looked at it yet but it don't like reving over about 3500k
Threads: 127
33
Car Model/Spec: ZX Volcane TD
Threads: 155
11
Was replace about 2 months ago
Threads: 55
Start it up and spray wd-40 all over the boost pipes, Mine did exactly this (minus the TD04) found out I had a hole underneath the intercooler pipe
Fabia vRS PD130 - New daily
Astra H VXR - new toy!
Threads: 226
24
Doesnt have to be wd40 anything flammable will do :p If the revs go up the hole is where your spraying lol
Threads: 36
18
Car Model/Spec: DT
(07-12-2012, 11:50 AM)Mowle5677 Wrote: Hang looked at it yet but it don't like reving over about 3500k
Next time your about get me or dan to check your throttle arm isn't set a notch out, should still rev higher than that even with a boost leak.
Threads: 155
11
Well I've just gone and got a new fuel filter to see if that helps.........
