23-11-2012, 08:34 PM
		Need to drain the water out of my 306 tonight as i have no antifreeze and there expecting -4 degrees weather.. Whats the easiest way to drain the block? Thanks
					Help...
		23-11-2012, 09:06 PM
		Dont think draining the radiator would be good enough would it? As there would still be water in the block.. Freezing very hard outside now!
		23-11-2012, 09:08 PM
		take the bottom pipe of. wont get it all out but if you run anti-freeze through it should be ok
Venetian XUD ph2 heaven Ph3 perv cab heaven Black ph1 XUD died Moonstone hdi stage 2
		23-11-2012, 09:51 PM
		There is a drain hole on the rad open that and let it pour out, then when it seems fully drained, blow into the filler neck make sure you get a good seal though so all the air pushed the water out. Replace bung, an fill
	 ![[Image: 20A1806D-891D-40FB-BD52-AD519177A607-734...391753.jpg]](http://i35.photobucket.com/albums/d196/mattbush/20A1806D-891D-40FB-BD52-AD519177A607-7340-0000058F46391753.jpg) TEAM CONROD SHITTING RALLYE!
		24-11-2012, 10:50 AM
		Got antifreeze today, how much water do one of these hold so i know what ratio to mix it? Thanks
		24-11-2012, 12:05 PM
		Actually i dont need to mix it, 9 liters do it??
		24-11-2012, 12:58 PM
	 (24-11-2012, 12:05 PM)Bananalad Wrote: Actually i dont need to mix it, 9 liters do it?? 9 litres!? You changing the antifreeze on your lorry lol?
		24-11-2012, 01:00 PM
	 (24-11-2012, 12:58 PM)Tom Wrote:(24-11-2012, 12:05 PM)Bananalad Wrote: Actually i dont need to mix it, 9 liters do it??  9 litres should be MORE than enough!   ![[Image: P1060836_zpsz3xgxt7q.jpg]](http://i1101.photobucket.com/albums/g427/wingnutz2/P1060836_zpsz3xgxt7q.jpg)
		25-11-2012, 10:24 AM
		I have no idea how much coolant one of these hold   Quick google search and the first number i seen was 9
		25-11-2012, 10:34 AM
		Don't no if this helps but my hdi was just over 7 litres
		27-11-2012, 11:58 AM
		If anyone is wondering in future the xud takes 7 and a half litres so i wasnt too far off with 9    |
