Car Model/Spec: 1.9 Non turbo estate
		Right here we go
firstly the interior light does not work on any of the doors but does turn on when switched on with doors shut
Secondly where the switches are for the cabin temp fan speed etc in the centre around the switches does not light up
How do I rectify these problems please
	Threads: 124
26
Car Model/Spec: Megane DCiR
		1st one will more than likely be the door switches held in chassis between door with torx screw be careful taking out as only have one wire on spade connector and pain in arse to get out if comes off switch
You will have to take the centre console apart there is a guide in guide section and the bulbs on rear need replacing
CJ
	Threads: 36
18
Car Model/Spec: DT
		I thought both these problems were standard on 306's...
My bets fuses ..
On the 306 waiting list.
		Ill check fuses first as they are much easier to do lol if not then ill change the door switches
