First of the problems - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Electrics (https://www.306oc.co.uk/forum/forumdisplay.php?fid=23) +--- Thread: First of the problems (/showthread.php?tid=7060) |
First of the problems - Willo - 16-10-2012 Right here we go firstly the interior light does not work on any of the doors but does turn on when switched on with doors shut Secondly where the switches are for the cabin temp fan speed etc in the centre around the switches does not light up How do I rectify these problems please RE: First of the problems - CJ_Derv - 17-10-2012 1st one will more than likely be the door switches held in chassis between door with torx screw be careful taking out as only have one wire on spade connector and pain in arse to get out if comes off switch You will have to take the centre console apart there is a guide in guide section and the bulbs on rear need replacing CJ First of the problems - Jake - 17-10-2012 I thought both these problems were standard on 306's... My bets fuses .. RE: First of the problems - Willo - 17-10-2012 Ill check fuses first as they are much easier to do lol if not then ill change the door switches |
