	Threads: 178
28
Car Model/Spec: HDi!
	Given 1 thank(s) in 1 post(s)
		Nothing too hard mate... Just slacken the pre tensioner and remove the old one, take a note (drawing) off the route that it takes and replace....
You may aswell replace the bottom pulley while your thier as they are common to failure too...
	Threads: 11
Car Model/Spec: 306 Hdi Dturbo
		cheers mate, i'll have a look , i know you can pick the belts up new ofc for pennies but what kinda cost you looking at for the bottom pulley?
	Threads: 117
119
		You say chirping noise, that's generally more related to a worn pulley, tensioner or power steering pump bearing. Worn aux belts usually make a continuous squealing noise when you first start the car in the morning, or after driving through a big puddle for example. I would say it's worth rotating all the pulleys and tensioners by hand while the belt is off to make sure all of them rotate freely and there's no feeling of stiction/graunching in the bearings.
	Threads: 11
		Cheers poodle will do, Thanks for your help Sean.
