02-01-2012, 11:11 AM
Has anyone got any pics of a MBC fitted to a K03? I understand how they fit on a GT15 but can't quite work out where it would go on the K03.
Any help appreciated
K03 MBC
02-01-2012, 11:35 AM
haha cheers for that ginge.. it's not quite the same on a K03 though, think the boost take off to the actuator is done through a banjo bolt
02-01-2012, 11:39 AM
you got any pictures to where you have access to ??
Phaes 1 GTI 6 - Onyx Black
02-01-2012, 11:44 AM
Nothing useful i'm afraid.. but i know there's naff all room. Hopefully someone who's already done it can pop along with a decent pic
08-01-2012, 11:42 PM
Cut the metal pipe in two, then jubilee clip some hose around the 2 bits of metal pipe.
09-01-2012, 12:10 AM
ginge191 Wrote:no expenses spared...that MBC is actually the wrong way round.. just sayin'
09-01-2012, 09:17 AM
What he said ^^ Flip it so boost is pushing spring not how it is
| #DervMafia | ![]()
09-01-2012, 09:23 AM
Cheers guys, What should i use to cut the pipe? Thinking about it won't it squash the pipe then give me effectively de-wastegate?
09-01-2012, 11:11 AM
Just cut it with penknife or something, its only a tiny rubber hose....
Better still remove it at both ends and run two longer new hoses up to somewhere easier to adjust! | Dyno Power Runs & Steady State Facilities Available, Just Ask Anytime |
| #DervMafia | ![]()
09-01-2012, 11:45 AM
Ah ok, ruan said it was a metal pipe? I've already got some hosing which i should be able to use, I'll take a load of pics when i do it for anyone else wondering
09-01-2012, 12:56 PM
If it's got a banjo bolt I assume it's a metal pipe?
I know the K14 uses a metal pipe, K03 might not - either way, just shove it someway between the two?
09-01-2012, 01:35 PM
Okay mate, it was difficult to see so not sure if it's a metal or rubber pipe, I'll see if i can get some decent pictures then that should tell me
09-01-2012, 03:05 PM
rubber pipe will be black and bendy, metal pipe will be metallic looking and not bendy
09-01-2012, 03:08 PM
mark_airey Wrote:rubber pipe will be black and bendy, metal pipe will be metallic looking and not bendy Unless it's all oily because i had a boost leak... in which case.. everythings black
09-01-2012, 04:53 PM
Midnightclub Wrote:Unless it's all oily because i had a boost leak... in which case.. everythings black The bendy rule still applies though
09-01-2012, 05:01 PM
I could do with pictures of this too.
09-01-2012, 05:05 PM
I'll be setting one of these up on a K14 soon. How easy is the pipe to access from underneath? Also what is the diameter, if anyone knows. Thanks.
09-01-2012, 06:48 PM
Jonny81191 Wrote:I could do with pictures of this too. No you couldn't, man up
09-01-2012, 07:44 PM
for the GT15, i just cut the pipe half way roughly, then pushed 2 fual line connector barbs in, then a few feet of blue silicone pipe up to near the top mount.
oh and i think its 5mm internal diameter, as the 6mm barbs i used were tight as f*ck..
09-01-2012, 10:16 PM
mark_airey Wrote:Jonny81191 Wrote:I could do with pictures of this too. get round to mine of an evening and help then! Welding and fabrication projects undertaken, contact me for more information.
