	Threads: 581
195
		its possible mate but i doubt it. They rarely break. If you can whip the sensor out, use a camera to take a photo in there and see if the pinion still has teeth on it!
How have you tested the wiring? Assuming just checked the continuity?
Could be a faulty speedo sensor (dont forget, just because its new doesnt mean it works!) or dials. Anything else on the dials not working?
	Threads: 86
		nope only thing on the dials not working is the speedo.everything works fine. cant get a camera down there for the life of it unless i have a microscopic one lol. With my old one it used to lose power then 1min later kick back in. as if something wasnt catching then it would catch again. put new sensor on (hoping to fix it) and now i get full power not 0mph doing my nut in and will be payin the garage to sort it as i need the car for work daily
	Threads: 581
195
		 (29-09-2012, 05:47 PM)ben87 Wrote:  nope only thing on the dials not working is the speedo.everything works fine. cant get a camera down there for the life of it unless i have a microscopic one lol. With my old one it used to lose power then 1min later kick back in. as if something wasnt catching then it would catch again. put new sensor on (hoping to fix it) and now i get full power not 0mph doing my nut in and will be payin the garage to sort it as i need the car for work daily
So your getting a signal at the plug for the dials?
	Threads: 86
		thats 1 thing i aint actually checked...will leave it to the garage had enough of messing with it
	Threads: 86
		04-10-2012, 04:22 PM
(This post was last modified: 04-10-2012, 04:26 PM by ben87.)
		Well my garage fixed it...he did exactly what I did,unplugged it cleaned sensor an pinion plugged it all back in and it worked! Bloody magician hands these garages have!
	Threads: 55
3
		 (04-10-2012, 04:22 PM)ben87 Wrote:  Well my garage fixed it...he did exactly what I did,unplugged it cleaned sensor an pinion plugged it all back in and it worked! Bloody magician hands these garages have!
Thats all I did to mine and it worked fine
Fabia vRS PD130 - New daily
Astra H VXR - new toy!
