	Threads: 448
51 Location: isle of wight
 Thanks: 17Given 18 thank(s) in 18 post(s)
		Got a massive banging from the rear. Like someone is hitting it from underneath with a hammer.
 It's not all the time. Just random. I thought it was on corners but it's not. Also not just on bumpy roads
 I suspect something has broken big time, what can it be?
![[Image: 20A1806D-891D-40FB-BD52-AD519177A607-734...391753.jpg]](http://i35.photobucket.com/albums/d196/mattbush/20A1806D-891D-40FB-BD52-AD519177A607-7340-0000058F46391753.jpg) TEAM CONROD SHITTING RALLYE!
	Threads: 63
26 Location: Bicester
 Car Model/Spec: GTi6
	Threads: 115
26 Location: Stow
 Car Model/Spec: 306
 Thanks: 3Given 0 thank(s) in 0 post(s)
		Rear beam mounts? Or f*cked beam? Bad luck dude hope you sort it
	Threads: 448
		I thought it could be the beam mounts, but I thought it would be a constant thing with them. Like over bumps or cornering?
 Would f*cked shocks cause a banging? As I have a feeling mine might be one their way out....
	Threads: 51
0 Location: Norwich buhh!
 Car Model/Spec: '96 ph1 DTurbo 'S'
		is it your back box? mine did this when it snapped off litterally on the back of the box
	Threads: 124
26 Location: Some dimension
 Car Model/Spec: Megane DCiR
 Thanks: 2Given 0 thank(s) in 0 post(s)
		Could be shocks but more likely to be rear mounts, ive had bushes go on a shocker which can cause such noise
195 Location: Bournemouth
       Thanks: 36Given 82 thank(s) in 78 post(s)
		First thing to do is MTFU, make a coffee and get under it and look for something obvious like something loose. Could well be a siezed shock or loose wheel bolts......
	Threads: 448
		Manning the f*ck up isn't possible as I'm at work till Thursday. Litterally all hours of the day as I'm covering 4 shifts in two days.
 May try and get out after lunch and see if anything is loose.
 It's not the exhaust. I had a feel of that, and it's solid. Only thing I can think of is the shocks or mounts. I've got solid mounts to fit. But I currently have no tools to do anything as my complete tool box is 50 miles away on loan :/
 Anyone free Thursday to fit mounts and shocks lol I'll pay in man love!
		For you Matt?
 No I'm not.
	Threads: 448
		Such a dick haha.
 Just checked the mounts are actually still connected haha. Nuts are tight on the inside. But pissing down and I'm meant to be at work haha
 When pushing down on the rear you can hear the gassy shock sound but that's it. I'll see if I can get done time to check under the car later when work get quiet
	Threads: 208
60 Location: Wiltshire
 Thanks: 1Given 5 thank(s) in 5 post(s)
		seems very strange, nothing catching the wheel? spare whel carrier? just some ideas
![[Image: DSC_0190-Copy_zpsf093f84d.jpg]](http://i1038.photobucket.com/albums/a468/167gti8/DSC_0190-Copy_zpsf093f84d.jpg) Member of 99% warning or your nothing club!
12 Location: Wrexham
 Car Model/Spec: 306 D Turbo
		To check the mounts you will need to jack the car up from the sills to let the beam hang down, you will then see if the mounts are still in one piece.
		 (25-09-2012, 04:58 PM)londondan86 Wrote:  To check the mounts you will need to jack the car up from the sills to let the beam hang down, you will then see if the mounts are still in one piece.
mine were FUBARD but still in 1 piece when on the car. Fell apart as soon as i took them off lol
	Threads: 115
26 Location: Stow
 Car Model/Spec: 306
		MTFU mine is sitting atleast 30mm lower drivers side and on my way home i took a left in to my close at around 5mph and the rear nealy overtook the front
		 (25-09-2012, 06:27 PM)R45_ODV Wrote:  MTFU mine is sitting atleast 30mm lower drivers side and on my way home i took a left in to my close at around 5mph and the rear nealy overtook the front
f*cked beam by the sounds of it?
	Threads: 115
26 Location: Stow
 Car Model/Spec: 306
		Yes mate very f*cked picking a uprated beam up on the 6/7th so should sort it out gona try not to use the car to much untill then tho
	Threads: 57
3 Location: Peterborough
 Car Model/Spec: 306 s16 406 v6 Saab 93 Ttid
 Thanks: 1Given 3 thank(s) in 3 post(s)
		Mine developed a bang like that a few years ago just as I was pulling on to the m25 by the dartford crossingOne of the bolts had fallen out of the shock mount!!!
	Threads: 448
		 (25-09-2012, 09:39 PM)swampy Wrote:  Mine developed a bang like that a few years ago just as I was pulling on to the m25 by the dartford crossingOne of the bolts had fallen out of the shock mount!!!
Oh... Not good. Will check that tommorow.
	Threads: 163
53 Location: Leeds
 Car Model/Spec: 406 HDI
 Thanks: 0Given 18 thank(s) in 15 post(s)
		Are you sure it's not more of a tapping noise?
	Threads: 448
		Fuuuuu liam
	Threads: 163
53 Location: Leeds
		Can't believe no-one had said that already tbh
	Threads: 448
		Meh. Me too tbh haha
	Threads: 169
91 Location: South London
 Thanks: 1Given 1 thank(s) in 1 post(s)
		It's your abs plugs smacking against the underside if the car whilt driving. Your gonna ed doe and Samass your car soon...
 Or the chassis leaving the beam behind?
![[Image: car-1.jpg]](http://i1117.photobucket.com/albums/k591/grant-306/car-1.jpg)  Member of the 99% warning or you're nothing club
	Threads: 448
		f*ck off haha. I genuinely think the diagnoses of "it's French" is good enough right now haha
	Threads: 541
124 Location: Aylesbury
 Thanks: 7Given 59 thank(s) in 58 post(s)
		I wouldnt worry, youll work out what it is when it falls off.
	Threads: 448
		Meh if it falls off then I know it's the mounts haha
	Threads: 448
		Right so new coil packs and spark plugs didn't sort it. It's better but not fixed. When driving it felt like there was a restriction. A blockage I had to put my boot down to get past. Over tightened aux belt cause this? Because my steering goes slightly iffy at the same time?
	Threads: 130
82 Location: Kingston
 Car Model/Spec: 106 GO-NAD
		fuelling issue isn't it? changed your fuel filter yet? checked the in tank pump?
	Threads: 448
		Haven't changed the filter as I didn't have time, will be done tomorrow.What do I look for pump wise? How do you know if they are f*cked?
119 Location: Southampton
 Thanks: 13Given 106 thank(s) in 106 post(s)
		Eh what? Your aux belt is causing a banging at the rear of the car...? I know your mechanics aint great, but that's a seriously tenuous link...
