	Threads: 150
14 Location: Beccles, Suffolk
 Car Model/Spec: 306 HDI
 Thanks: 0Given 0 thank(s) in 0 post(s)
		So got my mot this weekend just wanna be ready if it fails so here are bits I'm worried about.
 Running defilter
 t piece in brake vacuum for when I tried a DV
 low discs and pads (upgrading soon so no point replacing)
 lower engine mount knocking pretty badly
 decat
![[Image: 306ocsig_edited-1-1.jpg]](http://i1204.photobucket.com/albums/bb416/declantg/306ocsig_edited-1-1.jpg)  306 HDI, soon to be XUD
	Threads: 82
27 Location: North Somerset
 Thanks: 6Given 22 thank(s) in 22 post(s)
		From what i can tell none of that should cause it to fail, if they fail it for a decat then you should probably go to another garage...
	Threads: 150
		That's okay then, just hoping I don't suffer the 5dr rusty arches
	Threads: 82
		Rusty arch wouldn't fail anyway, only if it's structural and within 30cm diameter of a wheel IIRC
	Threads: 581
195 Location: Bournemouth
       Thanks: 36Given 82 thank(s) in 78 post(s)
		Declan its not just 5 doors I don't think. Think it's mainly ph1s and 2s
	Threads: 150
		This is starting to make me worry less about it! Every day my dad tells me it will fail...
	Threads: 82
		End of the day mate, worst case it fails, best case it passes, just chill bro
	Threads: 150
		Was hoping to pick up some seats this weekend though! Annoying as I have work 2-10 everyday now. So can't just sort bits out!
	Threads: 92
43 Location: Brizzle
 Thanks: 2Given 2 thank(s) in 2 post(s)
		Depends how low the pads are and what state the discs are in, could fail it on those
306oc Chat Wrote:15:30: Toms306 - :Genuinely thought it was gonna explode when I was playing with Sam22:57: SRowell - :wtf why didnt you try harder to make me come!
 ![[Image: connorsig.jpg]](http://www.306oc.co.uk/forum/images/uploads/connorsig.jpg)
	Threads: 82
		Ahh must've somehow missed that.. my rear pads were fairly low... only got an advisory for them though
	Threads: 92
		Like i said, depends how low, under 1.5mm is a fail
	Threads: 36
18 Location: Naarwich
 Car Model/Spec: DT
 Thanks: 0Given 2 thank(s) in 2 post(s)
		wont fail on engine mounts or defilter as mine passed with both those =L
On the 306 waiting list.
	Threads: 171
46 Location: Portsmouth
 Thanks: 0Given 1 thank(s) in 1 post(s)
		There is a limit on brake pad depth although they're not allowed to take the wheel off to check :-) must be visual
	Threads: 206
3 Location: far away
 Car Model/Spec: 3dr dt-s
 Thanks: 1Given 0 thank(s) in 0 post(s)
		rusty wheel arches do fail mot, as jagged edges are a risk to pedestrians
 if you can see through the whel trim/alloy wheel ,then if pads look to be below 1.5 mm they fail.
	Threads: 33
2 Location: Shrewsbury
 Car Model/Spec: 306 D-turbo/306 Rallye
		should all be good if the pads are not too low and the discs are in a ok condition, think im right in saying engine mounts are not looked at in the test? and they cant fail the de filter or the de cat!
Blaze '6 and Blaze D-turbo!
	Threads: 386
87 Location: Suffolk
 Thanks: 1Given 118 thank(s) in 117 post(s)
		Brakes will more than likely be an advisory unless they're that bad lol, also Id expect 'oil leak' which I had advised on most of my pugs lol.  And headlight aim will probably be out (which is a fail if bad enough) but they should just adjust this for you anyway.
