Threads: 376
38
Car Model/Spec: Phase 1 GTI 6
I've got a K14 in the shed I can rebuild for you. Ran fine when I used it?
Phaes 1 GTI 6 - Onyx Black
Threads: 171
46
Given 1 thank(s) in 1 post(s)
Wasn't the reason you changed that ginge because yours was on its way out?
Threads: 376
38
(08-08-2012, 04:24 PM)4WayDiablo Wrote: Wasn't the reason you changed that ginge because yours was on its way out?
Nope. I was getting a lot of smoke. Now found to be the fire ring for which I'll provide a new one ive got.
Thanks for your concern though.
Threads: 15
Car Model/Spec: Dturbo stage 2
yea that would be great that pal, how much would you be looking for it?
Threads: 170
5
Car Model/Spec: xud 1.9 dturbo
K14 £30
Venetian XUD ph2 heaven
Ph3 perv cab heaven
Black ph1 XUD died
Moonstone hdi stage 2
Threads: 376
38
take that ^^^^^
i cant post for much less than that; plus need the time to rebeuild; working solid for the next 2 weeks
Threads: 15
is that with postage karl? if not how much would it be mate?
Threads: 15
still need a turbo if anyone can help as mine is getting worse and now wont even boost over 15 psi!! any help will be great! thanks
Threads: 170
5
(08-08-2012, 11:21 PM)pud11 Wrote: is that with postage karl? if not how much would it be mate?
thats with out postage. were are you from?. the turbo is in castleford. its HDIKYLES
Ph3 perv cab heaven
Black ph1 XUD died
Threads: 15
as i said to hdikyle then atleast now theres loads of oil in my fmic and piping atleast i can see where my boost leak was by the puddle of oil under it
