Rub strip question
Rub strip question
Going to pick up a set of phase 3 rub strips for my phase 2 Smile Are they just the little plastic clips on to the door? And are the holes in the same place for the clips? Thanks Smile
Yeah lots of plastic clips. I didn't break one when talk g mine off it really isn't hard they usually stay in the bodywork when taking the strips off so you may need a small screwdriver to poke the grips in the back of the clip
Sound 4way Smile You know if phase 2 and 3 are the same?
Should be yeah, I've seen it done many a time before some hole may differ slightly but still go on fine
Thanks repped Smile
Depending on what wings you have on yours, the trims might not line up properly. If your wings have 4 holes then itll be fine, but if theres only 2 you might need to glue them on
Yes ph2 are the same as ph3 apart from the wing, the small one sits a tad low, I just broke out the clip holders the glued the plastic clip in the correct place on the back of the rub strip, simples Big Grin
