Crank sensor
Crank sensor
Hi guys
Right trying to get to the bottom of my non starting issue. Firstly the fuel ignition relay was clicking. I have replaced this but to no avail. But it has stopped clicking I've cranked the multi meter out and checked a few things .
Battery is good
Fuel pump primes both with the the relay in and when bridging the right pins.
I have fuel at the fuel rail.
Coil packs all have the required voltage when the required pins are bridged.
Next I checked the crank sensor. Firstly is this the crank sensor :-) secondly I have checked between all the pins and there is no reading of resistance. Does this mean it's knackered?
Is there an easy way to get it out? It looks fiddly as hell.
Attached Files Thumbnail(s)
Replacement is on route. Hopefully that works
Yes that's the crank sensor. Possibly to check output voltage whilst cranking?
  Gti6 crank sensor 318d4n 11 3,651 22-01-2013, 01:06 PM
Last Post: cjm_harris
