Threads: 169
91
Given 1 thank(s) in 1 post(s)
For wheel bearings. Who has experience with what? Don't want to get a cheap eBay jobby that will implode on itself rather than pull the bearing haha.
Don't want to spend masses, otherwise I can get them pressed, just handy tool to have if cheap enough.
Threads: 581
195
I've got one....
Threads: 90
54
Which bearings are you trying to pull?
You will want press for most of them... Unless we arnt talking about cars / 306's...
As for bearing pullers...if you want to use it more than once, any kit less than a few hundred is generally a load of poop....might get you out the crap once, but thats normally about it before they end up as a pile of cheese!
Threads: 169
91
Since when Niall?!? Wish I had known this sooner lol
And wheel bearings and lower engine mount Darren. You reckon it's worth getting it done then?
Threads: 581
195
I've got one up in the loft. Just never had a use for it!
Threads: 90
54
Which wheel beaings? What car?
Threads: 169
91
Front wheel bearings, 306.
Lower engine mount, 306, xu7jp4 although i think most of them are similar?
Threads: 91
83
Both need a press...
You can't pull wheel bearings... And you'll need to cut the old bearing out and then press in the new one tbh.
(16-05-2016, 10:45 AM)Toms306 Wrote: Oh I don't care about the stripped threads lol, that's easily solved by hammering the bolt in.
Threads: 19
5
Car Model/Spec: Ph1 D-turbo(on going project)
on the subject what about bearing pullers for removing torsion bars for lowerage.
Are cheapy ones not worth the hassle?
Threads: 36
18
Car Model/Spec: DT
Given 2 thank(s) in 2 post(s)
For removing mounts.. Fire & a hacksaw, FTW
Cant really help you on putting a new one in.
On the 306 waiting list.
Threads: 386
87
I just got the local garage to press mine out/in for a fiver............wasn't worth the hassle or cost of buying a press imo.
