can i add launch control to my gti-6?
i have been looking at cars with launch controll kits and i love how when holding it at the optimum revs on the launch controll kit the exhaust flames nicely however i can't seen to find a sutable kit can anyone help me?
I think there was an ad on for the Omex 600 ecu to Allow you to do that but spending over 500 on a ecu plus however much for the launch control is a bit excessive.
yes i won't be spending that money for one lol thanks for the reply i would have spent the 100 that i seen the kits for but they were for single coil or double coil engine's
thanks again paul,
Limit your throttle cable to about 4k, hold your foot on the floor at lights and dump the clutch. Simple!
Just learn how to drive, much cheaper lol
Launch control on an NA fwd petrol 306?
lol?
[Image: sigi-2.png]
It does have pretty uncontrollable torque...
You probably could yes... It's just whether 1AP accepts different timing or limits based on VSS...
However, for what it'd cost to have done and someone figure out, not worth it. You might as well go standalone from day one.
Other way you could do it is with a No-Lift Shift kit, it'd probably take in to account the clutch pedal position and then cut the ground to the coils when the revs go over a defined limit... It's just whether you'd end up wrecking the Coil Drivers doing that...
But why? A stock gti6 dosnt need launch control :S
[Image: sigi-2.png]
Oh no, I wasn't saying there was any point.
There isn't any!
The only time you might want to is for chronic flames, but the GTi6 exhaust manifold is fairly thin steel and will probably crack if you do.
(21-06-2012, 10:18 PM)Scott Wrote: It does have pretty uncontrollable torque...
only if they use NGK Spark plugs.
They push you back in your seat you know.
1. Fooby's Car
2. Fooby's Hire Car(s)
3. Fooby's Company Pool Car
Team Self Improvement
1. Learn to Car
Only if you get the "Iridium" ones...............lololololol
Team Orange Engine Bay
FFS, what is this?! Almost the ENTIRE mod-team cluste-trolling?! lmao
Has to be the Bosch super 4s mate. They give you 3 more sparks per cylinder you know.........
