Threads: 35
Car Model/Spec: 2001 XS 1.8
What are the quick shifts that people would recommend getting? I've seen some on eBay and they are about £65, but not sure if that's just the general price they are? I'm not bothered about getting a fake or copy one, as they will probably work the same, only thing ive heard about is the grub screw coming lose, but that's nothing some thread lock can't fix... Does anyone know where they are available for cheaper?
Threads: 171
46
Compbrake quickshift from top mounts on here are approx 30 quid and there is even a guide to fit them on here :-)
Threads: 208
60
Im just running a GE one and its spot on
Threads: 35
anyone know where i can get one for less than £60?
Threads: 92
43
On here... someone posted a link...
Threads: 35
thought that was just a guide?
Threads: 198
135
The Compbrake style quick shift alters the overall throw of the gear stick in ALL directions as it moves the pivot point of the gearstick. As a result, both side to side and forwards/backwards movement can be adjusted. It also increases the force meeded to change gear. Physics, y'see.
The GE style quick shift that bolts to the gearbox adjust forwards/backwards throw ONLY, but have little effect on effort required to change gear.
Combine the two like I have and you're left with one hell of a short shift, with a satisfying "thunk" as you bang it into gear.
Threads: 35
what are these GE things? any links?
Threads: 35
so if i combine one of those with one of top mounts quick shifts ill be getting some nice gear changes? i really dont like my gear changes at the moment, need a good push to get in gear sometimes :/
none of these parts will do any damage to my gearbox will they?
Threads: 198
135
Not likely, all that's happening is you're moving the relative pivot points on the gearbox/linkages. If you make it that short you have to force it into gear though then yes, you can damage the box long term.
Sounds more like the box/clutch is f*cked if you have difficulty getting it in gear.
Threads: 541
124
I have a compbrake style quickshift, brand new in its bag still that i maywell be interested in selling if the price is right
Threads: 86
GE shift does reduce the throw in all directions
Threads: 35
if you fit just the ball joint quick shift part, under the gear lever, does that make the gear movement any shorter? or does it just remove the wobble
