Peugeot Cat?
I recently took this off and replaced it with a Klarius Cat because it had a hole. I have since welded up the hole. I am not a welder! Is this a Peugeot or aftermarket CAT?  If it is Peugeot should I put it back on?
peugeot has PSA pressed in the centre of the body i believe
cant see your picture only the path step Wink
GTI6 Info
(21-04-2017, 02:14 PM)cully Wrote: peugeot has PSA pressed in the centre of the body i believe
Thanks Cully it does have PSA in the centre. Would you put it back?
I wouldnt sell it for sure as they are getting rare now
they are much better than the ECP cats
I still run a genuine CAT on my 6 which just sailed through its MOT emissions today
if i could fine another genuine i would buy it if the price was right just to keep on the shelf Wink
GTI6 Info
As cully said that's a genuine gti6 cat, worth keeping and worth refitting on the vehicle as it is better than pattern ones.
They snap there very often, I converted the joint to a sleeved fit and welded a flexi section in, but the cat itself is still good.
62k Diablo Phase 1 Gti-6:
Project Thread
[Image: attachment.php?aid=29699]
(22-04-2017, 05:31 PM)RetroPug Wrote: As cully said that's a genuine gti6 cat, worth keeping and worth refitting on the vehicle as it is better than pattern ones.
Do you have a photo of your mod?
doesn't need a flexi there as there's one at the top end.
(21-04-2017, 01:55 PM)KevinTW Wrote: I am not a welder!
We noticed! Rofl
(23-04-2017, 04:30 PM)welshpug Wrote: doesn't need a flexi there as there's one at the top end.
The part that sleeves inside the centre section gives it support, but I found after having converted it to a std. shorter sleeve fit that it snapped. Also my exhaust was moving a lot on sprints.
I think better engine mounts will help to sort this, but I put a flexi there at the time and it did help.
http://i66.tinypic.com/10418bm.jpg
Project Thread
