	Threads: 213
2 Location: The North
 Car Model/Spec: HDI
 Thanks: 52Given 16 thank(s) in 16 post(s)
		Did look good at Pugfest    guessing your running 21mm bars or some upgraded bars of some sort to lift the rear wheel? Sure ive only seen it on certain Gti6s
	Threads: 141
35 Location: Herefordshire
 Thanks: 3Given 14 thank(s) in 14 post(s)
		 (06-08-2016, 09:20 PM)MY95 Wrote:  Did look good at Pugfest  guessing your running 21mm bars or some upgraded bars of some sort to lift the rear wheel? Sure ive only seen it on certain Gti6s
Standard gti6 torsion bars but I have a hybrid rear anti roll bar with 28.5mm and 25mm ends rather than the standard 24mm. I prefer this setup to having 21mm torsion bars like I have on the dturbo daily
Current stable '09 Mercedes E320cdi wagon
	Threads: 541
124 Location: Aylesbury
 Thanks: 7Given 59 thank(s) in 58 post(s)
		Fit Jenveys or GTFO
 /thread
	Threads: 141
		More fannying around not fitting throttle bodies today :p
Changed the front springs again (third set this year) for eibach Pro 30s as the gmax 40s sat a couple of mm too low. So much better now, rides alot smoother and firmer, not crashing over bumps anymore either.
Now that the chassis is sorted i might finally get around to getting the jenveys fitted....  Maybe :p
	Threads: 47
14 Location: Browsing eBay for Turbos.
 Car Model/Spec: Ford cougar v6.  Mk6 Transit
 Thanks: 12Given 20 thank(s) in 20 post(s)
		Bollox will you.You'll just take off another bit, paint it and put it back on again.
 Just take inspiration from a certain Mr Rowel.
 Did his in a weekend with Toms and Bates for help, how hard can it be?
                                             ![[Image: 2ljm03k.jpg]](http://i57.tinypic.com/2ljm03k.jpg)
        I Don't Have A 306.
	Threads: 141
		 (20-08-2016, 08:16 PM)Danny Wideboy Wrote:  Bollox will you.You'll just take off another bit, paint it and put it back on again.
Aha you have a point
	Threads: 141
		I've done more procrastinating from fitting throttle bodies :p
 New brakes on the way, 6 pots this time which is huge overkill but they came up at a good price plus even with the extra pistons they're still thinner than the 406 brembos therefore giving me the choice of wheels fitment I was after
	Threads: 141
		Small road trip tonight to get some parts for the next batch of upgrades ;
305mm bells and rotors with 6 pot calipers and ebc yellow stuff pads
Adjustable droplinks with mot friendly rubber boots
Ultra lightweight flywheel (I'll do a weight comparison when I change them over)
Some brand new blackmasked lights (annoyingly I melted the lens of one of the current ones with some thinners
An intact battery and ecu tray with all the clips still in one piece
And some Peugeot sport numberplate surrounds as I've always fancied having them to fill the gap in the numberplate recess a bit better
Oh and this is how the car sits now everything's bedded in :
	Threads: 120
35 Location: Powys / Herefordshire
     Thanks: 147Given 40 thank(s) in 40 post(s)
		those are some porn brakes!!!
Team Cyril
	Threads: 141
		 (03-09-2016, 07:59 AM)Matt-Rallye Wrote:  those are some porn brakes!!!
I'll be fitting them later today if you're around sir
81 Location: Ipswich
 Thanks: 4Given 104 thank(s) in 102 post(s)
		So what calipers are these?
	Threads: 141
		 (03-09-2016, 05:24 PM)Eeyore Wrote:  So what calipers are these?
They're pug1off branded but all the part numbers for the caliper come up as AP for Aston Martin vanquish, so look they're just an ap caliper with a Peugeot hub adapter and a different face plate
	Threads: 141
		New brakes fitted tonight while I was waiting for the Mrs.
305mm rotors
Ebc yellow stuff pads
6 pot caliper
Perfect fit inside a 16" rim, and the best bit is that I've gone from having a cigarette paper of clearance between caliper and wheel to over 15mm compared with the previous 406 brembos!
Not had much of a drive yet as it was horrible weather but first impressions are a very good improvement over the old setup and that wasn't exactly a bad one!
Also fitted some Peugeot numberplate surrounds as I've always thought about getting some to fill out the 306 plate recesses a bit better
	Threads: 18
0 Location: Lisbon
 Car Model/Spec: 306 S16
 Thanks: 4Given 1 thank(s) in 1 post(s)
		 (04-09-2016, 12:49 AM)ozonehostile Wrote:  New brakes fitted tonight while I was waiting for the Mrs.
 305mm rotors
 6 pot caliper
Wow, what a nice brake setup ! Lovee that mate !
Sorry if you mention before I didn't see. What is the ET on that wheels ? I'm about to buy the same ones, Pro Race 1.2 right ?
PS: Lovely 6 mate I wish that I can be on the next hill climb
	Threads: 141
	Threads: 141
		![[Image: IMG_20160905_220448_zpsi4kpcncz.jpg]](http://i1310.photobucket.com/albums/s649/ozonehostile/Mobile%20Uploads/IMG_20160905_220448_zpsi4kpcncz.jpg)
Pretty happy with the car at the moment, it drives absolutely spot on and the stopping power is pretty impressive. It's definitely ready for more power now :p
	Threads: 18
0 Location: Lisbon
		Wow
You had braided lines with the brembos ? You had to buy 406 lines or the 306 ones its fine for that caliper ?
	Threads: 141
		 (07-09-2016, 09:40 PM)Pingaz Wrote:  Wow
Yeah I had braided, use a 306 flexi to a little adapter made out of copper brake pipe
	Threads: 18
0 Location: Lisbon
		 (07-09-2016, 09:50 PM)ozonehostile Wrote:   (07-09-2016, 09:40 PM)Pingaz Wrote:  Wow
Perhaps you have a picture ? I couldn't find on this post maybe i'm blind ? I think will do the same with the brembos on my S16 but i really need to know that it was good and plug and play. I know that in the hub this all ok, and you need 16" alloys.
Thank you
	Threads: 541
		Those really are porn brakes
		looks rubbish as always. :/ So is it possible to get the brakes not trhough p1off and save money? or are the adapters p1off design?
	Threads: 120
		 (09-09-2016, 02:42 PM)Eeyore Wrote:  looks rubbish as always. :/ So is it possible to get the brakes not trhough p1off and save money? or are the adapters p1off design?
Just buy my wilwoods and be done with it
Team Cyril
	Threads: 141
I guess you could buy the calipers but I highly doubt they'd be cheaper than buying them through p1o, Aston owners hardly worry about the money a pair of calipers cost I guess.
Plus then there's the hassle of having adapter brackets made, buying disc bells, brake hoses, pads, rotors....
Pretty quickly it'll come up to way more than p1o prices I'd guess
	Threads: 42
28 Thanks: 3Given 89 thank(s) in 88 post(s)
		godspeed brakes could sort you out easy.
	Threads: 141
		 (08-09-2016, 07:42 PM)Pingaz Wrote:   (07-09-2016, 09:50 PM)ozonehostile Wrote:   (07-09-2016, 09:40 PM)Pingaz Wrote:  Wow
 Thank you
Here's the 90 degree elbow you need, easy enough to make if you're handy with a brake flaring tool and they do fit under 15" wheels even with the 288mm xantia discs, the biggest issue is space between the caliper face and the back of the rim as these calipers are extremely chunky!
My new 6 pot setup has gained me about 15mm from where there was only a cigarette paper of clearance before
	Threads: 18
0 Location: Lisbon
		10-09-2016, 09:27 PM
(This post was last modified: 10-09-2016, 09:27 PM by Pingaz.)
		 (10-09-2016, 08:37 AM)ozonehostile Wrote:   (08-09-2016, 07:42 PM)Pingaz Wrote:   (07-09-2016, 09:50 PM)ozonehostile Wrote:   (07-09-2016, 09:40 PM)Pingaz Wrote:  Wow
 Thank you
That is actually pretty good, problem is that I don´t know who to make it really. But nice work you did there. My problem is, here in Portugal they want 350/450€ for a pair of these which is ALOT. I'm upgrading now to a 283mm from a 307 probably
Thank you for the pic mate, appreciated !
	Threads: 42
		buy them from the uk then ..
	Threads: 141
		Picked up a bargain set of vibratechnics engine mounts the other day, I already have the bbm group n set but these where too cheap to turn away
Also collected a new scorpion exhaust so that Matt can have his one back haha, my latest one is different from any other gti6 scorpion system I've seen in that it has a proper mid box rather than the slight bulge all the others I've seen have, would that make this an old or newer style system?
	Threads: 42
		much older is its a full box, looks similar to a magnex?
 iirc both used to be a collins performance brand.
	Threads: 141
		 (20-09-2016, 07:13 PM)welshpug Wrote:  much older is its a full box, looks similar to a magnex?
Yeah, I thought it was a magnex mid section at first but it's got the scorpion logo etched on the top
