	Threads: 170
Venetian XUD ph2 heaven
Ph3 perv cab heaven
Black ph1 XUD died
Moonstone hdi stage 2
	Threads: 170
		Been a pain messing around with mounts ect but it's in and runs. Just abit more niggly bits and connect pipes ect then done
![[Image: 2af495bca773f63bbd864cd11e5b5eba.jpg]](http://images.tapatalk-cdn.com/16/01/24/2af495bca773f63bbd864cd11e5b5eba.jpg)
![[Image: f8ad5d002ccc65e01ff1c0a9209796e8.jpg]](http://images.tapatalk-cdn.com/16/01/24/f8ad5d002ccc65e01ff1c0a9209796e8.jpg)
Ph3 perv cab heaven
Black ph1 XUD died
	Threads: 186
38
Car Model/Spec: MG ZR VVC
		Long time no see pal. This going super chronic boost or just enough to make the daily drive a bit more bearable?
	Threads: 170
		Eyup how's it going?  Safe boost for now not finished yet should be by Saturday. Do have big turbo ect already [emoji106]
Ph3 perv cab heaven
Black ph1 XUD died
	Threads: 170
Ph3 perv cab heaven
Black ph1 XUD died
	Threads: 61
11
		Plan sounds good,can't wait to see it done.
	Threads: 170
		Van is done. Had to change box, clutch, flywheel, timing belt and also move rear fork for lower mount. Now done but not 100% just a few niggly bits left. Also fitted the stereo
![[Image: bdbd0e8956c5d6aa492feb8654938437.jpg]](http://uploads.tapatalk-cdn.com/20160328/bdbd0e8956c5d6aa492feb8654938437.jpg)
Ph3 perv cab heaven
Black ph1 XUD died
	Threads: 170
		02-04-2016, 10:51 PM
(This post was last modified: 02-04-2016, 10:51 PM by karl1989.)
		![[Image: e599a2c2c6431ffa9da2f77dea2db77e.jpg]](http://uploads.tapatalk-cdn.com/20160402/e599a2c2c6431ffa9da2f77dea2db77e.jpg)
Need some wheels now
![[Image: 9c9aa8e9af6425743d95ff75ff352b3c.jpg]](http://uploads.tapatalk-cdn.com/20160402/9c9aa8e9af6425743d95ff75ff352b3c.jpg)
Ph3 perv cab heaven
Black ph1 XUD died
	Threads: 170
		![[Image: 7084270e313f679c8d6a14efa2c790db.jpg]](http://uploads.tapatalk-cdn.com/20160406/7084270e313f679c8d6a14efa2c790db.jpg)
Custom sticker
Ph3 perv cab heaven
Black ph1 XUD died
	Threads: 38
Car Model/Spec: D'turbo S
		Hi looking good the 1.9D is pretty dead how is it having the DT?
Was it fairly straight forward?
As I've possibly gotta stick a XUD in a belingo multi space and Had a couple questions if I may
Which box did you use?
How did the turbo exhaust elbow work out?
Final don't suppose you have a picture of the lower mount?
	Threads: 170
		Now I know everything yes. Was a pain at the first. Used Xud box with all the Xud mounts. I've got a down pipe of a xantia work fine enough room. As for the lower mount the fork needs to be removed and moved over there is a hole already there just have to drill it too make it abit bigger. What shape is the multispace?
Ph3 perv cab heaven
Black ph1 XUD died
	Threads: 38
		12-04-2016, 08:48 PM
(This post was last modified: 12-04-2016, 08:50 PM by blinkyeatu.)
		ahhh nice one man thats really helpful ill have a look into it.
guess i would call it phase 1 same front end as yours however its gold and gold/green interior :/ absolutely awful
have you or and are you doing a brake and axle upgrade?
	Threads: 170
		Mines the ph2. Not sure on axle upgrade as these axles do well with weight so may leave it
Ph3 perv cab heaven
Black ph1 XUD died
