Threads: 19
Country:
30-11-2015, 04:19 PM
1. When I was driving home from work my car was driving fine below 2000 revs but as soon as I put my foot down my car starts to judder like its starved for fuel and won't go anyware.
2. The gti6 inlet manifold iv bought off eBay is a Citroen one, is everything still the same.
Threads: 476
81
Car Model/Spec: 306 Rallye
1. When was it last serviced? Poor spark causing misfiring? either sparks or coil packs? Does the dash do anything?
2. If they look the same then they should be the same. I am unaware of any variants. Its the same engine.
Threads: 19
Country:
I changed the oil, spark plugs n fuel filter about 6 months ago, I drove through a flooded road earlier tho.
Threads: 476
81
so... did this happen only after driving through the flood.
Threads: 19
Country:
Yeh but like an hour later
Threads: 136
11
Later Citroën vts manifolds have different injectors for starters
Threads: 448
51
That flood, could be your issue mate
Threads: 541
124
Is your manifold plugged in correctly. There is one of the plugs (I think the yellow one) that gives those symptoms if it's left unplugged.
Threads: 386
87
I'd check all the plugs for water as well...
How big was the flood? I assume it wasn't high enough to reach the air filter. I've seen this issue happen with a faulty (wet) crank sensor on a HDi but may not affect the petrols in the same way.
Threads: 19
Country:
About a foot deep.
I drove to work this morning and it seems fine now.
Threads: 19
Country:
Lol I'll see what the drive homes like
Threads: 19
Country:
Its driving fine now must of been water on something
