Custom oil line, how long?
mark_airey Wrote:Clearly straight into the turbo looking at the angle of it Dan, and what banjo fitting?
Actually, thinking about it, is the T25 not the same size oil inlet as the T2?
because why not just move the adaptor from the T2/K14 and just use the steel line??
Thats if its a T25 that your fitting? I don't think you have actually said!
You cant see what angle the center cartridge is at so it could be a banjo fitting. And Jakes is a TD04L, the standard oil in line had a banjo bolt/fitting.
#32
Dan! Wrote:You cant see what angle the center cartridge is at so it could be a banjo fitting. And Jakes is a TD04L, the standard oil in line had a banjo bolt/fitting.
No it couldn't, doesn't matter what angle its on, that is clearly screwed straight into the inlet, mine has an M10 banjo bolt on the turbo end.
I get the impression you just think I'm being a lady garden with the way your responding so I will stop trying to help you now because clearly I wouldn't have a clue Smile
Team Orange Engine Bay
#33
this is mine i had pritek make its for a td04l
[Image: 2011-12-24125929.jpg]
its 460mm from were the fitting fits to the line to the other and seams plenty long enough theres still plenty to have it held back to the block
[Image: 2011-12-31125130.jpg]
#34
Thanks alot for that Ash, really helpful.
