	Threads: 110
20
Car Model/Spec: Estate, DT, GTI6 and 205
	Given 30 thank(s) in 30 post(s)
		Im going to be fitting a 1.9 dt lump in a 205 and want to know whether to worry about pluming up the standard oil cooler? Ideally i do want to but poss at a later date.
If people have plumed them in where have they run the pipes from?
	Threads: 61
4
	Given 6 thank(s) in 5 post(s)
		I found with mine all I've got is the aftermarket sandwich plate and have to run a stubby oil filter and it's very close to the radiator as it is so with the standard cooler aswell you will have space issues
	Threads: 591
54
		Yeah you want the standard one ideally
Check out service box for diagram but essentialy one side goes to thermostat housing outlet, other goes to the rad
	Threads: 61
4
		In a 205 one goes to the thermostat housing and the other goes to the top rad hose but as said space is a major issue
