205 xud oil cooler - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: 205 xud oil cooler (/showthread.php?tid=32280) |
205 xud oil cooler - Frosty - 19-10-2015 Im going to be fitting a 1.9 dt lump in a 205 and want to know whether to worry about pluming up the standard oil cooler? Ideally i do want to but poss at a later date. If people have plumed them in where have they run the pipes from? RE: 205 xud oil cooler - aggyj17 - 19-10-2015 I found with mine all I've got is the aftermarket sandwich plate and have to run a stubby oil filter and it's very close to the radiator as it is so with the standard cooler aswell you will have space issues RE: 205 xud oil cooler - Piggy - 19-10-2015 Yeah you want the standard one ideally Check out service box for diagram but essentialy one side goes to thermostat housing outlet, other goes to the rad RE: 205 xud oil cooler - aggyj17 - 19-10-2015 In a 205 one goes to the thermostat housing and the other goes to the top rad hose but as said space is a major issue RE: 205 xud oil cooler - Frosty - 20-10-2015 Cheers guys. I did think that would be the case. Need to get a T piece to put in the top rad hose. Not cheap though in the size i need
205 xud oil cooler - aggyj17 - 20-10-2015 ![]() Here's a pic of mine |
