low miles Estate .
Yeah once I get them out I'm just gonna put standard bolts back in lockers are a pain in the ass
#32
Yeah them 1s are a right pain. Best place for lockers is the bin tbh
#33
Yh we found that one out frosty
Wouldn't have been so bad if the wasn't so tight
#34
Well small update all the lockers are now out had to use the welder on all of them Sad
Also the car is now sitting on some cyclones
Will get some pics at some point
Also Darren has downloaded my ECU and has been sent off to TB for a map
I also have been having some problem with fuel pressure and the car going in to limp mode so we cleaned out the fpr and checked all the o rings was still in tack
After this the car seam's to be back to it normal self
Also has had a small service oli, oil and filter and fuel filter
MOT is next on the list whick is in the 20 of this month then I will be dropping the front end by 40mm
And I might give the cyclone a refurbishment with some new slippers Wink
Still want some arch liners on both sides if anyone got any there going to bin Smile
#35
Right then cyclones are on
Also the car has been mapped now after a few problem I was having the seems to be pulling really well Smile
#36
Well finally washed to car today and spent more than 20 minutes doing it Smile
Scrubs up pretty well
Few snap shots
[attachment=22538][attachment=22539]
#37
Looking real good mate. Hows it pulling with a map on it?
#38
Pulling a lot better now dont really know what else to do now than lower the front down a bit
Got any ideas
#39
Hmm yeah defo see about lowering it.
Get a straight through exhaust if you haven't all ready is usually a must
#40
Yeah they bastard s,amount of time iv slipped with the wrench with them
[Image: Cn91r40h.jpg]
#41
Yeah a got a dcat pipe but dont wanna be loud at all
What makes them a bastart?
#42
You washed it ?! :O
[Image: sigi-2.png]
#43
What you trying to say Wink
#44
Well she now all moted
Nothing happening for a min with the car as change of jobs now using her as a van till I buy one
Then I can crack on with a few bits and bobs
#45
Ideal, need much for mot?
#46
Went straight through
Advised on rear pads and a tyre which I new about
So pretty happy really
#47
Well got round to lowering my car to day only took 5mins and 20 bags of sand [attachment=22918]
[attachment=22919]
#48
(29-04-2015, 09:26 PM)daniel909 Wrote: Went straight through
That was alright then. You coming to any of the shows this summer?
#49
Ffs puncher number 3 in the estate could not be asked to stop so carryed on driving the 500 yard home Smile[attachment=23254]
Might come to the next local meet but no shows sadly don't have the time with the new job ATM
#50
some boy!!
#51
Some Bleddy Boi I really need a van
[attachment=23290]
#52
Some bledy boy!
#53
Well I broke down yesterday went in to limp mode and keeps cutting out then won't start when it does
Goes straight back in to limp mode got six fault codes
To of which are old which I did not have cleared that the maf sensor
[attachment=23502]
#54
Try unplugging the Maf and start her up and see if it still cuts out or runs in limp mode, if it does try removing the Maf and use a good solvent based cleaner to clean all surfaces, connectors and pins etc, refit and see if it makes any difference!
#55
The MAF fine as it brand new old faults
#56
Its basically telling you the rail pressure is too high and it thinks the cause is a jammed regulator....
#57
What could be causing this problem dirty fuel ?
#58
Rhys just had quick look, pretty sure its the pressure reg on the pump playing up, as its running on / rail pressure is all to cock, have tried cleaning it that once before so probs need a new one...
[Image: sigi-2.png]
#59
Ah feck shall I go up combellack and get one f*ck buying new
As I need to spend out on rear breaks as mine are shot
#60
Yeah can do, think I have a box with brand new pads also
[Image: sigi-2.png]
