Threads: 51
Car Model/Spec: '96 ph1 DTurbo 'S'
what temperature is the cold side of my turbo where the pipe from the airbox goes on lightly to be?
im just wondering what material i could use to make some pipe work up so i can run my airfilter to down near the bumper for better airflow.....
Threads: 177
Not a good idea to put the air filter any lower, best to put it in behind the headlight, it will suckup water and the slightest look at a puddle. iv destroyed one engine, strange it dident snap the rod, only put the crank in two bits
Threads: 51
what diameter? and has anyone got any experience of using plastic tubing? the company i used to work with used it on the inlet on the k series but obs there not turbo dont know if it is lightly to melt, im thinking it will just wondering tbh
Threads: 150
14
Car Model/Spec: 306 HDI
Hang on, are you putting it so it goes directly into the turbo?
You would want it to have a gap, then filter.
=====/ )==== like that
306 HDI, soon to be XUD
Threads: 51
so not a pipe ruuning straight onto the turbo with a cone filter on the end of that?
Threads: 150
14
they way im doing it is to have some piping running from fog light to a gap just about the air filter for the turbo
That would work fine Joe, but it would work better if it had a good supply of cold air, maybe from behind the headlight as dec suggests. Plastic tubing probably wouldn't be suitable as the turbo is tucked down the back of the engine in an area being pumped with heat from the engine block and exhaust manifold. Silicone doesn't cost that much these days tbf.
