	Threads: 61
11 Location: Bury  St  Edmunds Suffolk
		18-12-2014, 02:28 PM
(This post was last modified: 18-12-2014, 02:28 PM by 7057sam.)
		Sound good in the video,is it running a decat
Nout wrong with part hording,I should know I got a shed full of shinies
Any updates on the bodies??
	Threads: 141
35 Location: Herefordshire
 Thanks: 3Given 14 thank(s) in 14 post(s)
		 (18-12-2014, 02:28 PM)7057sam Wrote:  Sound good in the video,is it running a decat
 Nout wrong with part hording,I should know I got a shed full of shinies :lol:
Nope, just a low mileage oem cat on at the moment, although when it's eventually bodied I'll probably decat it to preserve the cat
As for bodies, I've got rallye aux setup to fit, fit epas as the current pas pump location fouls the trumpets
I've got a complete spare engine for trial fitting parts so hopefully the actual fitting will be straight forward
Current stable '09 Mercedes E320cdi wagon
	Threads: 61
		20-12-2014, 11:16 AM
(This post was last modified: 20-12-2014, 11:18 AM by 7057sam.)
		Ah cl always wondered which would be less of a ball ache to do a epas or relocating the pas pump as was a bastard to do on my charger,snapped the bolt which hit me in the face
Then used to leak,guess it goes across instead of straight down,so any tiny leak would be put under more pressure
	Threads: 141
		I'm mostly going for epas so if I blow it up I'll still have power steering to get it on the back of a recovery truck haha
	Threads: 141
		Still no throttle bodies, but I have been hoarding nile stuff haha ![[Image: IMG_20150107_212731_zps827e2770.jpg]](http://i1310.photobucket.com/albums/s649/ozonehostile/Mobile%20Uploads/IMG_20150107_212731_zps827e2770.jpg)
	Threads: 120
35 Location: Powys / Herefordshire
     Thanks: 147Given 40 thank(s) in 40 post(s)
		That looks really really purple in those pics!
Good hoarding though man
Team Cyril
	Threads: 141
		 (08-01-2015, 01:03 PM)Matt-Rallye Wrote:  That looks really really purple in those pics!
Yeah nile looks totally different in artificial light, I love it. The massive halogen lights at petrol stations are the best for purple gti6 haha
	Threads: 141
		Hello again!
After a few months of gathering dust at the back of the unit it's probably about time I got the 6 ready for summer
Changing jobs and training for another job hasn't given me much time to do anything to it but the "to be fitted" pile has been ever growing
Latest purchase as a motivational piece to renew my insurance
 ![[Image: received_10152639286611403_zpssinrn6xo.jpeg]](http://i1310.photobucket.com/albums/s649/ozonehostile/Mobile%20Uploads/received_10152639286611403_zpssinrn6xo.jpeg)
On that topic, after dropping the front 60mm the mcphearson strut design has left me with a bit of positive camber on the front so hoping to reset to standard castor and camber just with the lower ride height if anyone happens to have the specs handy??
	Threads: 15
2 Location: prescott hill
 Car Model/Spec: XSi
 Thanks: 2Given 18 thank(s) in 17 post(s)
		07-04-2015, 08:26 PM
(This post was last modified: 07-04-2015, 08:28 PM by adam b.)
		Castor as much as you can, camber about -0.5 is standard. Slight toe in, say 3 minutes. Lower it goes you'll get more toe in.
 I thought you'd get negative camber from lowering it...?
 Oh and check the rear toe/camber just in case the beam isn't on straight. Not unknown.
P1 XSi track car2.4 LWB T4
	Threads: 141
		Ah cool, from talking to baker bm reps at pugfest the adjustable strut tops have a certain amount of extra castor for high speed stability iirc
I don't think it has gone to actual positive camber but compared to a standard height gti6 you can certainly see the difference in angles.
I did have thought about the beam when I swapped it so had four wheel laser alignment to check and it's pretty spot on
	Threads: 120
		Our beam changing skills are faultless    did we fit solid beam mounts? i cant remember
Team Cyril
	Threads: 141
	Threads: 120
Team Cyril
	Threads: 141
		Got the 6 up on the ramp to see what it's looking like underneath since last summer, fortunately caught this just in time!
Kinda suspected it might have needed attention since the other side needed welding but luckily this side was still solid
I'll pick up some oxide primer and underseal tomorrow and sort it properly    ![[Image: 20150414_184823_zps7gzqxuyf.jpg]](http://i1310.photobucket.com/albums/s649/ozonehostile/Mobile%20Uploads/20150414_184823_zps7gzqxuyf.jpg)
54 Location: Cotswolds
       Thanks: 22Given 68 thank(s) in 68 post(s)
	Threads: 120
		Mmmm crusty blurple
Im free saturday afternoon if my undersealing skills are required
Team Cyril
	Threads: 61
		Ahhhhh rust fwends
Mine went in exactly the same place.
	Threads: 110
20 Location: Devon
       Thanks: 1Given 30 thank(s) in 30 post(s)
		I've had to tidy my dt up on them bits at the moment. Common place for them to go, the 306s are starting to show there age now
	Threads: 141
		A few thread pages back I needed to weld the other side and at that time the passenger side was fine. Soon as there's a hole in the underseal it seems those box sections start rotting. Just glad I caught this side before it needed welding too
	Threads: 541
124 Location: Aylesbury
 Thanks: 7Given 59 thank(s) in 58 post(s)
		Lowering should increase negative camber (make it lean in at the top more)
	Threads: 141
		Stocked up on wire wheels and zinc primer and had a nice manly evening  ![[Image: 20150414_191424_zpsneizrnvf.jpg]](http://i1310.photobucket.com/albums/s649/ozonehostile/Mobile%20Uploads/20150414_191424_zpsneizrnvf.jpg)  ![[Image: 20150415_210114_zpsjjk7lkix.jpg]](http://i1310.photobucket.com/albums/s649/ozonehostile/Mobile%20Uploads/20150415_210114_zpsjjk7lkix.jpg)
Let that dry overnight and underseal it all tomorrow, got a bit carried away and did the entire floor pan. Shouldn't have any more rust issues for a while now!
	Threads: 141
		16-04-2015, 12:51 PM
(This post was last modified: 16-04-2015, 12:55 PM by ozonehostile.)
		[attachment=22685]
 First coat of underseal went on this morning.
 While the underseal was drying decided to fit the powerflex rear bump stops that I've had in the cupboard for a couple of years now. Typically good intentions of getting stuff done went wrong with the bump stop cup retaining bolt snapping off and having to drill it out etc, but still, good opportunity to buy some unesessary shiny things from spoox
 [attachment=22686]
	Threads: 141
		Found a big issue today    ![[Image: 20150419_191407_zpso4yest3h.jpg]](http://i1310.photobucket.com/albums/s649/ozonehostile/Mobile%20Uploads/20150419_191407_zpso4yest3h.jpg)  ![[Image: 20150419_195452_zpse14ag1ry.jpg]](http://i1310.photobucket.com/albums/s649/ozonehostile/Mobile%20Uploads/20150419_195452_zpse14ag1ry.jpg)  ![[Image: 20150419_195515_zpsasyg4wcr.jpg]](http://i1310.photobucket.com/albums/s649/ozonehostile/Mobile%20Uploads/20150419_195515_zpsasyg4wcr.jpg)
Didn't want to cut anymore out until I've found a complete donar sill to weld in.
Scary to think that this has been hiding under the side skirt for years, looks to be damage from a jack on the sill that split the metal and has been rotting from the inside out, repairing the outer sill shouldn't be too bad it's just where the rot has started eating through the inner sill that concerns me.
The welder is on standby, just need to find a donar car to chop up lol.
Not what I wanted to find the week before I was going to put it back on the road!
	Threads: 102
18 Location: Warwickshire
 Thanks: 0Given 22 thank(s) in 22 post(s)
		Wow that's not good. Glad you're going to get it sorted though. I'm putting off removing my sills.
My 306 is rusty behind the front arches in pretty much the exact same way as yours.
	Threads: 141
		I've been poking around some more this morning and it goes deeper than I first though
The repairs to the sill are likely to lead to needing to respray the rear quarter.
Bit of a dilemma really as this is doable but not cheap, but I've been offered a very tidy rallye for the same sort of money that repairing this would cost :/
	Threads: 120
		 (20-04-2015, 11:33 AM)ozonehostile Wrote:  I've been poking around some more this morning and it goes deeper than I first though
Store this and be my black rallye broseph, Got the whole summer to repair this beasty then!
Team Cyril
	Threads: 141
		23-04-2015, 03:53 PM
(This post was last modified: 23-04-2015, 04:17 PM by ozonehostile.)
	Threads: 141
		Got the guy at manumech next door to my workshop to bend me up a section of replacement sill from some 1mm steel, top blokes. Absolutely perfect  ![[Image: 20150423_131511_zpsugw54imd.jpg]](http://i1310.photobucket.com/albums/s649/ozonehostile/Mobile%20Uploads/20150423_131511_zpsugw54imd.jpg)
	Threads: 136
2 Location: Norwich
 Thanks: 1Given 1 thank(s) in 1 post(s)
		Horrible to find rust like that! But at least you know what your doing and your cracking on with the fix, good stuff!
