(10-02-2015, 09:42 PM)Toms306 Wrote: I've already tried telling Chris this...
But anyway - £400 for mapping...where the hell is that!?
No what you've said is you'll never clear all the carbon.out of the engine with turbo failure, what that does is carbon blocks the strainer/filter in the Hp oil line and stops oil getting to the turbocharger, but it wasn't blocked in the first place as the engine was clean on the inside, no thick sludge etc.
If that'd happend with this turbo there wouldn't be oil in the exhaust because it would have blocked the Hp filter and no oil would be getting to the turbo.
The engine is self is fine. I can only put it down to the "cheap" turbo or the decat and the reason I say decat is because it could be over speeding the turbo now cat is empty. Because yer it is wastegated turbo but controlled by vacuum so could be the vacuum control isn't reacting quick enough. All tho I could be wrong.
And the mapping was with hdi-tuning think his name Steve? Something like that. There very complex tho so I'm told.
