12-12-2014, 10:56 PM
		So my expansion tank is full of oil for some reason. Could this be the heat exchange/sandwich plate? the temperature isn't effected by it so not sure if it will cause any damage long term?
if it is the sandwich plate what one will i need? searching on eBay all i could find was this mocal one.
http://www.ebay.co.uk/itm/MOCAL-OTSP1F-M...2343ed5ea0
it says it isn't a replacement it should only be used in conjunction with an oil cooler, which I'm not sure will be much use to me. (unless its worth fitting an oil cooler?)
So can anyone point me in the right direction for a new one.
Thank you guys
Thank you guys
