	Threads: 1
		So after nearly 7 dry years of ownership my Pug has developed a slight water leak from lower water hose coupling at the radiator. It's the 'spring clip' type of coupling and I intend to replace O ring seal soon. However, I understand that corrosion on bottom hose sleeve might be reason for leak and not seal itself. So question is, has anyone reassembled one of these joints successfully with a generous smear of silicone compound either side of the seal?  A new bottom hose is not cheap!!!!
	Threads: 591
 54
		Just get a second hand hose for a fiver
	Threads: 581
 195
		Yep several times. Old seal off, clean it up with a wire brush. new seal is 60p from pug (careful, they do two sizes) and refit with a smear of grease. Done
	Threads: 465
 114
 Car Model/Spec: Vauxhall
		part number is
1343 Z4 - later type bottom hose seal ring + top hose seal ring to thermostat housing
	Threads: 1
		Thanks for the info guys - Will go a new seal and hope only minor corrosion on hose sleeve.
	Threads: 42
 28
		 (05-11-2014, 07:51 AM)cully Wrote:  part number is
nope, Stan was so wrong.
1339 94 O-RING DIAM INT 31 EP 3,6
is for the top hose.
1343 Z4 ENGINE WATER END-PIECE GASKET DIAM 31-38 EP 3,5
is only for the bottom hose.
	Threads: 465
 114
		Welshpug are you sure the two are different as I've fitted the same square profile ring to both the top and bottom hose
I'm sure the o,ring is for the earlier lower hose with the plastic clips
	Threads: 1
		OOPS - Have I started something here - LOL. Mines the later 'spring clip' type bottom hose connection. 'O' ring seal?
	Threads: 42
 28
		 (05-11-2014, 09:20 PM)cully Wrote:  Welshpug are you sure the two are different as I've fitted the same square profile ring to both the top and bottom hose
yup, top hose one is fatter
	Threads: 465
 114
		 (05-11-2014, 10:35 PM)welshpug Wrote:   (05-11-2014, 09:20 PM)cully Wrote:  Welshpug are you sure the two are different as I've fitted the same square profile ring to both the top and bottom hose
dont want to start a fight... but...FIGHT!
the 1351X9 earlyer bottom pipe uses the 133994 O-ring
the later 1351Z3 & 1351ZV pipes use the 1343Z4 end piece seal
each top hose I have taken off has always had the square profile ring not the o-ring?
[attachment=19932]
	Threads: 465
 114
		hold the horses!! this is in the TU engine section not XU!
CARBURETTOR TU3-2 + INJECTION TU3JP  UNTIL RPO No. 07972
1307 V8   RING-SEAL 33,5X3,15
CARBURETTOR TU3-2 + INJECTION TU3JP  SINCE RPO No. 07973 + TU5JP INJECTION
1343 Z4  END-PIEC GASKET DIAM 31-38 EP 3,5
	Threads: 42
 28
		lol
but yes I am 100% on the top hose being the part number I quoted
	Threads: 1
		Thanks for info folks - I have asked my local friendly independent garage to order the seal. Lets see
 what comes  - LOL
	Threads: 371
 29
 Car Model/Spec: ford fiesta
		Ok I seem to be a pikey then. Grab an o ring out the box of 700,091,726 I have in my workshop bang it in. Job done.
	Threads: 1
		16-11-2014, 08:30 PM
(This post was last modified: 16-11-2014, 08:33 PM by Pugant06.)
		Well disconnected hose from rad, cleaned off corrosion and fitted new seal lubricated with silican grease and reassembled. Thought it felt a lose fit when I pushed it back in place. It's leaking worse now
Replacement seal from Peugeot was square section and same as one removed. I now regret not smearing area with instant gasket on assembly. I can only assume that I removed too much material in the groove that seal sits in when cleaning up and its not seating tightly. Might try and get O ring seal that's oversize next attempt. Any ideas?
 (06-11-2014, 09:16 PM)bashbarnard Wrote:  Ok I seem to be a pikey then. Grab an o ring out the box of 700,091,726 I have in my workshop bang it in. Job done.
You obviously know something from experience with this problem?
	Threads: 1
		SORTED
Reassembled again with new seal smeared Granville instant silicon gasket and now still dry after a good bleed and 100 miles use.
Now why the hell did I not do that in first place
	Threads: 42
 28
		because if its the correct seal there's no need and tis a right bodge?
