Threads: 164
25
Car Model/Spec: Gti6
Given 4 thank(s) in 4 post(s)
28-09-2014, 09:01 PM
(This post was last modified: 28-09-2014, 09:03 PM by rocker8742.)
What is this plug for? Behind the inlet/throttle body on the 6
2 pin black plug anyone know?
Orrrr any sensors that would fail suddenly and leave a gti struggling to pull and hunting at idle
Already checked the lambda and its not that
Threads: 11
Car Model/Spec: 306 GTI-6 trackday toy
Given 2 thank(s) in 2 post(s)
Icv? Under the throttle body.
Threads: 164
25
28-09-2014, 09:27 PM
(This post was last modified: 28-09-2014, 09:57 PM by rocker8742.)
Checked the icv mate its not that afaik
Threads: 386
87
Think that plug's for the inlet air temp sensor?
Hunting and struggling to pull sounds like a broken MAP sensor though.
Threads: 183
20
Given 8 thank(s) in 8 post(s)
Its a free plug mate! Pretty sure mine has it!
Threads: 18
10
Car Model/Spec: 3 x 205 GTi & 306 HDi
As above, the black 2-pin plug is unused on UK cars.
(for reference of the above posters, on a GTi-6 the IAT plug is grey and the ICV is a black 4 pin ovalish connector and not a JPT like shown)
Threads: 476
81
Car Model/Spec: 306 Rallye
This question comes up time and time again.... i may be stupidly wrong but wasnt it something like a throttlebody heater for colder climates or something?
Threads: 18
10
Throttle heater plug is yellow and is used on UK cars despite not really being needed in our mild climate.
Threads: 476
81
oh thatll be what i was thinking of then!
Threads: 164
25
Damn was hoping its be the problem, is a map sensor likely to go faulty all of a sudden?
Threads: 18
10
They can do, as can ignition coils - both common on '6 engines.
Threads: 386
87
(29-09-2014, 09:50 AM)powerandtorque Wrote: As above, the black 2-pin plug is unused on UK cars.
Any idea what it's used for on the non-UK models? Something to do with cruise control maybe? Just intrigued now lol.
(29-09-2014, 04:21 PM)rocker8742 Wrote: Damn was hoping its be the problem, is a map sensor likely to go faulty all of a sudden?
Can do yeah. One failed on SRowells 1.8 without warning...at the time we went to the scrappy to get a load of spare sensors to try...all except a MAP sensor.
Ph2 '6s aren't OBD compatible are they? And I guess you don't have PP2k?
Threads: 164
25
No haven't got any diagnostics stuff .
Got a spare map sensor which il try tonight , fingers crossed .
Threads: 476
81
so they have a plug but they cant be read by most readers. think its only peugeot plane that will do the job.
Threads: 386
87
Yeah didn't think they would be. They didn't need to be OBD compatible until 2001. So it is only Pug Planet you'd be able to check with unfortunately.
Might as well try the MAP as you've already got it spare though!
Threads: 164
25
Swapped the map sensor over and it appears to have fixed the issue, odd that it went all of a sudden thoug
Threads: 19
12
(29-09-2014, 07:05 PM)rocker8742 Wrote: Swapped the map sensor over and it appears to have fixed the issue, odd that it went all of a sudden thoug
It's peugeot nothing is 'odd'
glad to hear its back to normal
Threads: 128
21
Car Model/Spec: Stage3 HDi RHF5@25psi 174bhp
Given 41 thank(s) in 38 post(s)
the weather became considerably colder over the last few days mate, so possibly that had an effect on the vehicle, and this wasnt a noticable issue prior to that.. but now is..
/Toseland
Threads: 541
124
(08-10-2014, 02:04 PM)toseland Wrote: (29-09-2014, 07:05 PM)rocker8742 Wrote: Swapped the map sensor over and it appears to have fixed the issue, odd that it went all of a sudden thoug
Yeah my car is being a right bitch since the temperature has dropped 10 degrees.
Threads: 128
21
which one? the decent one or that shitty Faillye
/Toseland
Threads: 465
114
Car Model/Spec: Vauxhall
Tom i have planet here if you needed to plug it in to have a view at whats being read by the sensors
Threads: 26
4
Given 6 thank(s) in 6 post(s)
Just for future ref, you dont need pug planet for ph2's, my delphi system reads them fine.
Threads: 591
54
(09-10-2014, 05:16 PM)toseland Wrote: which one? the decent one or that shitty Faillye
Rep'd!!
Threads: 164
25
(09-10-2014, 05:26 PM)cully Wrote: Tom i have planet here if you needed to plug it in to have a view at whats being read by the sensors
Will bear that in mind for future mate
