	Threads: 52
 Car Model/Spec: Ph2 Dturbo
		Toxic-Jake Wrote:Diggers Wrote:How much? I payed less that a quid for mine
Sent from my HTC Wildfire using Tapatalk
Got a link or where you got it from?
& Cheers Ben... not quite how i want her yet but getting there   got it from pug in gy,
	Threads: 36
 18
 Car Model/Spec: DT
		sweet.. will check it out cheers (Y)
On the 306 waiting list.
	Threads: 36
 18
 Car Model/Spec: DT
		Oh & This...
![[Image: 331ziw4.jpg]](http://i40.tinypic.com/331ziw4.jpg)  90ppl ftmfw
	Threads: 87
 31
		Mmmmmhhhhmmm    Where you getting it from mate? I love the smell, gonna have to convoy somewhere soon so I can have a sniff lol    You going to the EA meet on Sunday?
	Threads: 70
 7
 Car Model/Spec: Astor GTI6
		Dan! Wrote:Mmmmmhhhhmmm   Where you getting it from mate? I love the smell, gonna have to convoy somewhere soon so I can have a sniff lol   You going to the EA meet on Sunday?
Buy the 205 back and smell it yourself
Also veg FTMFW.
	Threads: 36
 18
 Car Model/Spec: DT
		From bookers mate.. 19.80 for 20L. Just put in 20l with 20l deisel. Will be putting rest in straight when that's used.
	Threads: 22
 Car Model/Spec: 306 1.4
		This is the only reason why I would have a diesel!
	Threads: 36
 18
 Car Model/Spec: DT
		Don't you drive a 1.4?
	Threads: 171
 46
		So jim... not the extra power and better fuel economy? :-P
	Threads: 22
		Nope, mine sounds better! 1.4 ftw!
	Threads: 36
 18
 Car Model/Spec: DT
		Why is this happening?
Water pump has gone! And now this is happening?
Blue smoke out of the exhaust too!
Head gasket?
	Threads: 129
 11
		How's the coolant? It could be piston rings
Stage 2 XUD Sedan
	Threads: 36
 18
 Car Model/Spec: DT
		None existent, the water pump has died and promptly ejected all my radiators Contents on to the floor.
Would piston rings require a new block?
	Threads: 129
 11
		Toxic-Jake Wrote:None existent, the water pump has died and promptly ejected all my radiators Contents on to the floor.
Yeah more than likely. Best have that head off and investigate.
Hope it's just the head gasket.
Stage 2 XUD Sedan
	Threads: 266
 18
 Car Model/Spec: 205 DTurbo
	Given 7 thank(s) in 7 post(s)
		That doesn't look to good, hopefully its nothing to serious though.
	Threads: 36
 18
 Car Model/Spec: DT
		strictly_derv Wrote:Toxic-Jake Wrote:None existent, the water pump has died and promptly ejected all my radiators Contents on to the floor.
Yeah the heads coming off and getting skimmed on Saturday but I really do think that it's something more than that! Shame though the engine is only on 75k.
	Threads: 92
 43
		Make sure the head is tested and not just skimmed
	Threads: 36
 18
 Car Model/Spec: DT
		What do you mean conner, quite new to this whole head gasket failure thing!
Edit : Connor? Sp?
	Threads: 48
		Pressure tested
Peugeot 206 GTI HDI
Volvo V50 2.0d
Volvo XC90 D5
	Threads: 36
 18
 Car Model/Spec: DT
		Anton Wrote:Pressure tested
Ah right , yeah it's getting pressure tested tomorrow  hopefully!
	Threads: 90
		What makes you think the waterpump is gone ?  Sure its not just by all in all? Or is pump itself leaking ?
	Threads: 36
 18
 Car Model/Spec: DT
		darrenjlobb Wrote:What makes you think the waterpump is gone ?  Sure its not just by all in all? Or is pump itself leaking ?
Pretty sure the pump is leaking, .  Start with Empty rad -> 3L or water In the rad. All pisses out of an area just behind the cam belt,  just presume its the water pump..
	Threads: 92
 43
		Don't forget theres a plastic water distributor down the back of the block in that area
	Threads: 36
 18
 Car Model/Spec: DT
		Hmm yeah I remember someone saying about that! , as said I will be taking a proper look at it over the weekend, and deciding the plan of action then, I may not even need to get the head machined yet! Might not have warped!  Could be an easy fix, ( but As we all know it's never that simple !)
		You haven't popped w core plug have you?  I dunno where they are on a dt so might be wrong area though.
	Threads: 87
 31
		We dont know whats wrong yet. My diagnosis of waterpump was literally from sticking my head under the car and having a quick look. I wasnt in the situation to start stipping the engine down to check everything, but il remember to check water distributer and core plug. I suppose saying the waterpump has gone isnt strictly true, probably just the gasket between pump and block, but its worth changing anyway once its all apart.
	Threads: 90
		If the pumps leaking its most likely coming from the shaft, so will need replacing, be suprised tho as surely iris has this thing serviced up well ?
	Threads: 129
 11
		Don't forget Jake mentioned blue smoke out the exhaust. So it's burning oil somewhere.
Check the bores for any scores and pistons for damage.
Stage 2 XUD Sedan
	Threads: 87
 31
		Yeah, properly pouring blue smoke out even at idle when I met up with him, not good at all. Would be a real bastard if the rings are fecked, especially considering the mileage this engine has done.
	Threads: 9
 19
	Given 3 thank(s) in 1 post(s)
		Dan! Wrote:Yeah, properly pouring blue smoke out even at idle when I met up with him, not good at all. Would be a real bastard if the rings are fecked, especially considering the mileage this engine has done.
Milage the engine has done or mileage the clocks say its done? and if its pouring out blue smoke I would check the intake side of things after the turbo just in case its that blasting oil down the intake!
