30-04-2014, 09:21 AM
		Does the scoop in the bonnet liner actually channel air to the IC? IS THERE any way to modefy it to make it better?
HDI D'Turbo Daily Driver ---- XUD D'Turbo Project
					bonnet liner
		30-04-2014, 09:41 AM
		I did test it at one point, and it was actually pretty efficient. I'm sure somebody will be along shortly with another opinion.
		30-04-2014, 10:19 AM
		Yeah thought that. Mine was hangin down so I pulled it off. Only afted realised that it channelled air up to I.c. If you could get a bigger opening in it or extend it down closer to the front id say it would be lots efficient?
		30-04-2014, 12:13 PM
		I doubt quite highly that you will improve on it, when the car is moving there's a decent amount of air pressure un the fan cowling area that any air not going through the rad will go up through the intercooler.
		30-04-2014, 02:19 PM
		So should i definatly try and pin bak up the liner or just leave it off is what im wonderin?
		30-04-2014, 02:20 PM
		I would fit it, get new clips.
		01-05-2014, 11:27 PM
		I'd leave it on for the sake of it. FMIC really is the best way to get cool air imo.
		02-05-2014, 10:56 AM
		Get a wire coat hanger  make it rectangle and put it in to hold the front of the opening open. A Genuine Original Kwik bodge that helps loads lol.
		02-05-2014, 09:27 PM
		Yeah mite do that because its pretty squashed lookin.  Just drilled holes and cable tied it up. Not arsed gettin clips   HDI D'Turbo Daily Driver ---- XUD D'Turbo Project |
