Top mounts
Top mounts
Ive got ta technix coilovers on the front at the moment and they seem to make some kind of bouncing noise would this be because I've got standard top mounts on?
Im debating on getting some kyb top mounts off ebay? Are they any good??
Kyb are Oem on most cars these days including Peugeot iirc.
I've noticed that ta technics do seem to have a habit of eating through topmounts though so worth changing if the rubber has began to perish
Ok cheers ill probably get a set then.
And with the rubbers ill have to have a look. Would that explain the bouncy kinda noise?
Dont forget bearings when changing top mounts. Worth doing for the extra £10
Current - 306 ph1 xrdt - 323 estoril. History - Legacy Outback - Impreza Wagon - BMW 530 - Golf GTI mk2 - Escort TD - Audi 80 coupe - Astra GTE - Escort XR3
Project : http://306oc.co.uk/forum/thread-23625.html
Ive got a feeling they come with the bearings but ill double check. Thanks
Probably just TA Technix tbh.
Cause there cheap yeah aha
I had to change mine last weekend with the same problem
