Top mounts - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Suspension, Transmission, Handling & Braking (https://www.306oc.co.uk/forum/forumdisplay.php?fid=19) +--- Thread: Top mounts (/showthread.php?tid=23683) |
Top mounts - Nicks306 - 30-04-2014 Ive got ta technix coilovers on the front at the moment and they seem to make some kind of bouncing noise would this be because I've got standard top mounts on? Im debating on getting some kyb top mounts off ebay? Are they any good?? RE: Top mounts - ozonehostile - 30-04-2014 Kyb are Oem on most cars these days including Peugeot iirc. I've noticed that ta technics do seem to have a habit of eating through topmounts though so worth changing if the rubber has began to perish Top mounts - Nicks306 - 30-04-2014 Ok cheers ill probably get a set then. And with the rubbers ill have to have a look. Would that explain the bouncy kinda noise? RE: Top mounts - nick000 - 01-05-2014 Dont forget bearings when changing top mounts. Worth doing for the extra £10 Top mounts - Nicks306 - 01-05-2014 Ive got a feeling they come with the bearings but ill double check. Thanks RE: Top mounts - Eeyore - 01-05-2014 Probably just TA Technix tbh. Top mounts - Nicks306 - 01-05-2014 Cause there cheap yeah aha RE: Top mounts - parky306 - 01-05-2014 I had to change mine last weekend with the same problem |
