	Threads: 581
195 Location: Bournemouth
       Thanks: 36Given 82 thank(s) in 78 post(s)
		So, something I've been thinking about for a while now is some form of hydraulic clutch set up on the standard 306 gear boxes. I know after a few thousand miles of use, the 306 clutches seem to get very heavy which isn't that nice! Anyone else ever thought of this and if so, how far did you get with looking into it? I was thinking of using a slave cylinder on top of the box actuating the original clutch arm, then a master cylinder of some sort on the pedal its self then am i correct in thinking, its a case of piping between the two with and filling with fluid? Would i need a vacuum at all or would the set up be as simple as master cylinder piped into slave and thats it?
	Threads: 177
3 Location: Highlands, Scotland
 Thanks: 0Given 0 thank(s) in 0 post(s)
		Wont need a vacuum, you could make it even easier by keeping a cable of sorts and mount the master cylinder in the bay
	Threads: 581
		SO would just need the original cable pulling on something like thishttp://www.wilwood.com/MasterCylinders/M...o=260-6087
Which is then piped to the slave cylinder on the box? Correct?
	Threads: 177
		The only problem with that is that MC you need to push, the cable would pull on it.
I still don't think this will fully solve the problem, you would either need to fit a slave cylinder like this
 ![[Image: 1203clt-14%2B5-speed-gearbox-install%2Bc...linder.jpg]](http://image.classictrucks.com/f/tech/1203clt_5_speed_gearbox_install/36702400/1203clt-14%2B5-speed-gearbox-install%2Bclutch-slave-cylinder.jpg)
or keep the cable and re-design the real problem, remove the nylon bushes holding the fork ,machine out the holes and fit some sealed bearings
	Threads: 591
54 Location: Cotswolds
       Thanks: 22Given 68 thank(s) in 68 post(s)
		Dont mean to "do a Piggy"...
 But have a search as I asked this question when I was building and gathering info for the 2.1 GT...
 There were some options, but I kept it simple in the end
	Threads: 119
15 Location: Rotherham/Sheffield
 Car Model/Spec: Ph1 Diablo DT
 Thanks: 0Given 1 thank(s) in 1 post(s)
		04-02-2014, 11:48 PM
(This post was last modified: 04-02-2014, 11:54 PM by Jenkosowls.)
		Pull clutch slave cylinder http://www.wilwood.com/MasterCylinders/M...20Cylinder
Just then need a master cylinder by the pedal and connect it up
I take it that the gti6 is a pull clutch like a Dt?
www.prestige-auto-care.co.uk
	Threads: 127
33 Location: London
 Car Model/Spec: ZX Volcane TD
 Thanks: 6Given 32 thank(s) in 32 post(s)
		I think the Picasso hdi uses a remote slave cylinder that bolts on the outside of the gearbox and actuates the fork rather than a cylindrical slave.
 Might be worth looking at that setup to see how it works, as could well retrofit 306
	Threads: 162
21 Location: Dunstable
 Thanks: 0Given 23 thank(s) in 23 post(s)
		 (05-02-2014, 09:04 AM)zx_volcane Wrote:  I think the Picasso hdi uses a remote slave cylinder that bolts on the outside of the gearbox and actuates the fork rather than a cylindrical slave.
The 206 2l hdi has this also.
	Threads: 177
		Could mount that push type under the pivot point of the pedal but i still think machining out the gearbox to take bearings would be easier and work better
	Threads: 92
43 Location: Brizzle
 Thanks: 2Given 2 thank(s) in 2 post(s)
		Most of the psa clutches work like that afaik^^
306oc Chat Wrote:15:30: Toms306 - :Genuinely thought it was gonna explode when I was playing with Sam22:57: SRowell - :wtf why didnt you try harder to make me come!
 ![[Image: connorsig.jpg]](http://www.306oc.co.uk/forum/images/uploads/connorsig.jpg)
	Threads: 42
28 Thanks: 3Given 89 thank(s) in 88 post(s)
		berlingo/partner pedal box and BE4 gearbox casing (can be from cable as well as hydro), standard berlingo/partner clutch hydraulics, standard PSA BE4 release bearing and clutch arm job done
	Threads: 581
		Just FYI, ill be going ahead and doing this in the next few weeks so will do a guide on it. Does anyone know the distance the clutch arm swings to release the clutch properly?
	Threads: 92
		Only about 3-4" id have thought, not massive
	Threads: 162
		23-02-2014, 08:37 PM
(This post was last modified: 23-02-2014, 08:38 PM by DeeTurbo.)
		 (23-02-2014, 07:54 PM)Connor Wrote:  Only about 3-4" id have thought, not massive
Yeah not massive but we're talking about clutch release movement mate!
	Threads: 92
		And your point is?
	Threads: 162
	Threads: 92
		Ok ive missed something here lol
	Threads: 169
91 Location: South London
 Thanks: 1Given 1 thank(s) in 1 post(s)
		 (23-02-2014, 07:06 PM)Niall Wrote:  Just FYI, ill be going ahead and doing this in the next few weeks so will do a guide on it. Does anyone know the distance the clutch arm swings to release the clutch properly?
Measure it you lazy tart.
As we said earlier, just use a complete 206 setup. Cheap enough and already pre made pretty much. Fabricate a mount for the M/C to meet the pedal and then use the black cradle on the front of the gearbox to mount the S/C to...
![[Image: car-1.jpg]](http://i1117.photobucket.com/albums/k591/grant-306/car-1.jpg)  Member of the 99% warning or you're nothing club
	Threads: 162
		23-02-2014, 09:13 PM
(This post was last modified: 23-02-2014, 09:14 PM by DeeTurbo.)
		 (23-02-2014, 09:12 PM)Connor Wrote:  Ok ive missed something here lol
Just my attempt at humor.
	Threads: 169
He is saying you have a little willy
	Threads: 92
		O I C what you there
