Threads: 151
14
Car Model/Spec: 306 D-turbo
19-10-2013, 04:29 PM
(This post was last modified: 19-10-2013, 04:30 PM by Danny2009.)
Having issues with the car
Won't rev past 3.5-4k gov is shimmed solid so is not that, it drives like it's not goved
White smokes the street out when cold and hunts like its on veg
Fuel filters clean and so is the strainer
Only ran on shell diesel
Warm or cold it smokes white and diesel knocks Dosent smoke as much when warm only when revving the engine, fires straight up when cold but smokes so it's not glowies
Tried advancing and retarding pump makes no if little differance
Anyone have any ideas?
Team Doesn't own a 306
Threads: 87
48
timing out on belt? . . .
Threads: 151
14
Good shout ill check that what would cause it to stop reving tho
Threads: 266
18
Car Model/Spec: 205 DTurbo
Mines been doing this since I bought it and more recently strange noises are coming from the pump/belt so it would well be timing. I need to get mine checked when the Bosch goes on.
Threads: 151
14
Just don't understand how it won't rev under load or idle just won't do it
Seriously thinking about breaking it (que the vultchures)
Threads: 170
When mine wouldn't rev at all it was the gov that went into pieces in the pump. Think Jenk still has the remainder of the pump full with springs and washers lol
Venetian XUD ph2 heaven
Ph3 perv cab heaven
Black ph1 XUD died
Moonstone hdi stage 2
Threads: 151
14
Don't think it's that pal took the gov out other day,
It revs round to 5k now at idle but pops like a petrol backfire and when you let off the revs if won't idle just cuts out then runs like shit on start up
Threads: 266
18
Sorry I meant mine smokes white and hunts even on diesel like yours but it doesn't stop it reving - not that I can see what its reving to as I have no tacho.
Threads: 170
Sure you got throttle arm on ok. Check injectors too
Ph3 perv cab heaven
Black ph1 XUD died
Threads: 226
24
Car Model/Spec: A3 TDi
That sounds like the timing stuff inside the pump is f*cked, take the lid off again and check your gov is still there lol
Threads: 151
14
I had the top off last Saturday it was still there and it was doing it before but another look won't hurt
Threads: 136
11
Is the actually timing of the derv pump ok?
Threads: 151
14
Sorted it, stripped the threads on the studs the pump goes on so wasn't nipping up properly and pump was moving about
Replaced the studs and it's ok now
Threads: 136
11
You must of been bollocking them up then!
But yeah that would cause your problem
Threads: 151
14
Yea bit heavy handed like things tight
Ahh well live and learn least it's sorted
Threads: 87
48
nice one mate good to hear...
