Won't rev amongst other things - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: Won't rev amongst other things (/showthread.php?tid=18160) |
Won't rev amongst other things - Danny2009 - 19-10-2013 Having issues with the car Won't rev past 3.5-4k gov is shimmed solid so is not that, it drives like it's not goved White smokes the street out when cold and hunts like its on veg Fuel filters clean and so is the strainer Only ran on shell diesel Warm or cold it smokes white and diesel knocks Dosent smoke as much when warm only when revving the engine, fires straight up when cold but smokes so it's not glowies Tried advancing and retarding pump makes no if little differance Anyone have any ideas? RE: Won't rev amongst other things - Mattcheese31 - 19-10-2013 timing out on belt? . . . RE: Won't rev amongst other things - Danny2009 - 19-10-2013 Good shout ill check that what would cause it to stop reving tho RE: Won't rev amongst other things - silverzx - 19-10-2013 Mines been doing this since I bought it and more recently strange noises are coming from the pump/belt so it would well be timing. I need to get mine checked when the Bosch goes on. RE: Won't rev amongst other things - Danny2009 - 19-10-2013 Just don't understand how it won't rev under load or idle just won't do it Seriously thinking about breaking it (que the vultchures) RE: Won't rev amongst other things - karl1989 - 19-10-2013 When mine wouldn't rev at all it was the gov that went into pieces in the pump. Think Jenk still has the remainder of the pump full with springs and washers lol RE: Won't rev amongst other things - Danny2009 - 19-10-2013 Don't think it's that pal took the gov out other day, It revs round to 5k now at idle but pops like a petrol backfire and when you let off the revs if won't idle just cuts out then runs like shit on start up RE: Won't rev amongst other things - silverzx - 19-10-2013 Sorry I meant mine smokes white and hunts even on diesel like yours but it doesn't stop it reving - not that I can see what its reving to as I have no tacho. RE: Won't rev amongst other things - Danny2009 - 19-10-2013 Timings fine RE: Won't rev amongst other things - karl1989 - 19-10-2013 Sure you got throttle arm on ok. Check injectors too RE: Won't rev amongst other things - Tom - 19-10-2013 That sounds like the timing stuff inside the pump is f*cked, take the lid off again and check your gov is still there lol RE: Won't rev amongst other things - Danny2009 - 19-10-2013 I had the top off last Saturday it was still there and it was doing it before but another look won't hurt RE: Won't rev amongst other things - Paul_13 - 19-10-2013 Is the actually timing of the derv pump ok? RE: Won't rev amongst other things - Danny2009 - 19-10-2013 Sorted it, stripped the threads on the studs the pump goes on so wasn't nipping up properly and pump was moving about Replaced the studs and it's ok now RE: Won't rev amongst other things - Paul_13 - 19-10-2013 You must of been bollocking them up then! But yeah that would cause your problem RE: Won't rev amongst other things - Danny2009 - 19-10-2013 Yea bit heavy handed like things tight Ahh well live and learn least it's sorted RE: Won't rev amongst other things - Paul_13 - 19-10-2013 I've learnt my lesson many times, snapped wheel bolts mainly and a couple of caliper bolts
RE: Won't rev amongst other things - Mattcheese31 - 20-10-2013 nice one mate good to hear... |
