	Threads: 12
		well the car went in for my first Mot, its pug 1.6 8v, basically rear brake imbalance, low effort seized load sensing valve linkage  nearside outer front cvj gator
nothing too drastic, so get looks like spanners at the ready, any advice on the gator replacement would be helpful[/size][/font]
	Threads: 195
 6
 Car Model/Spec: 2000 Xs 1.8 16v
		Hmm fiddly little job that, ive been known to buy second hand drive shelf's back in the day
		I would just wack a shaft on.
seized compensator is easy...wd40 and pliers.
and just service the rear brakes
	Threads: 12
		that's my thoughts too, 1 cheaper 2 quicker and less mess too.
	Threads: 202
 58
		Buy a replacement boot and wresutle it on. I did this just tonight. It's a pita but with 2 people it's certainly doable with no special tools
	Threads: 12
		 (17-10-2013, 09:04 PM)Jonny81191 Wrote:  Buy a replacement boot and wresutle it on. I did this just tonight. It's a pita but with 2 people it's certainly doable with no special tools
what the boot cost you I seen them for about 9 quid
	Threads: 127
 33
 Car Model/Spec: ZX Volcane TD
		replacing outter cv boot?
piece of cake, can do it without removing shaft and draining gearbox oil if you're careful.
slice old one off with a stanley knife
get a universal stratch boot and either
actually stretch it over using a bucket of lube and a cone, which is a pita
or knock the cv joint off the shaft by tapping it it with a mallet
fit cv boot and tap it back on, making cure the circlip is located on the end of the shaft.
if you don't have a magic crimper for doing the fiddly metal clips that  hold it on, just use some good old zip ties
Did one couple of days ago, no sweat!
Certainly not worth messing removing a shaft, catching oil, and refilling gearbox.
		knocking the cv joint off can be a right pita though
	Threads: 12
		they wanted to charge me 90 for fitting on a new one, yeh right!
	Threads: 92
 43
		I wouldnt advise knocking the cv joint off unless you know what you are doing, the little circlip on the end of the shaft (that goes into the cv joint) can be a bitch at the best of times
		Thats exactly what I was thinking...
sometimes you can flick a little screwdriver in there and it just pops off...
but sometimes its a proper two man job
	Threads: 206
 Car Model/Spec: 3dr dt-s
		stretchy boot and cone, don't even bother wrestling cv joints off anymore
	Threads: 0
	Threads: 6
		I'd recommend a Bailcast stretchy boot . Stretchiest I've come across and use plenty of lube on your cone!
	Threads: 90
		Stretchy boots are ftw tbhj. save alot of farce.
	Threads: 6
		Don't be tempted by the cut and glue ones. Might be okay on a RWD but I don't trust them on a FWD car.
 Car Model/Spec: BMW 330Ci/VW Up/205GTi/205Mi16
	Given 5 thank(s) in 5 post(s)
		Done this myself a year or so ago on my 1.4. Buy a quality boot kit too, some are shite and split easily. Bung the boot in a bucket of very hot water beforehand, this helps soften it up for stretching over the cone tool.
Be wary knocking the CV joints off, some are the spider type joint.
	Threads: 24
 Car Model/Spec: Hdi Dturbo
		You want a rhino rubber boot, i use them on all cars universal, super stretchy and have a lifelime guarantee, i use a pneumatic boot spreader but work well with the cone too. Remember with the cone though to turn the boot inside out 1st or else ul get it on  and itl be back to front and have to take the joint off or cut it off =epic fail
