	Threads: 92
43
	Given 2 thank(s) in 2 post(s)
		Check the sides of the boot. There are access holes on both sides, if you dont have the covers and/or rear arch liners, water will get in
	Threads: 94
		I had this before, taillight was letting in water and making its way to there
	Threads: 386
87
		Are you sure you don't have a rusty hole in the rear arch?
	Threads: 202
58
		Bet it's the door seal, the one on my wagon was leaking, swapped it for a good one and it's all watertight again.
	Threads: 448
51
		I have the same. In a 3dr. Would be nice to fin the fault
	Threads: 11
1
Car Model/Spec: Ph3 Meridian HDI
		Check the tailgate seal.
I had a car with the same problem but not a 306 and it turned out to be this. You could try putting someone in the car and give it a good soak with a hose around and suspect areas.
