The Airbag and you...For MOT !!
(19-07-2013, 07:15 PM)Niall Wrote: There not difficult to fix at all. 9 times out of 10, its just a case of cutting off the plugs on the seats and soldering! Airbags rarely go wrong
Exactly this, usually ten minutes with a small screwdriver fixes the problem.
I thought that Connor but I took the dash out today and there was clearly a missing bulb and I looked underneath and it says air bag quite clearly
#33
Ignore that Stephen Peugeot do that to save money having to make multiple dials. Mine have the water in diesel filter warning light...Errr don't think that applies to my car lol
#34
I thought that, but then it's got marks where a bulb used to be there, which is odd
#35
Pop one in, see what happens? Lol
Yeah probably should of, it's all back together now though!
#37
(20-07-2013, 02:33 PM)Stephen Wrote: Yeah probably should of, it's all back together now though!
ahhh this is the thread for me!! So I have constant light on now. its just failed its MOT, im not interested in the airbag working anyhow my 306 is also a 98 reg so in theory I don't need a light on full stop. can i just start hacking at the cables below my seat or do I need to go cutting elsewhere? thanks. Steve
#38
I had this fella! Change the connectors for bullet or spade ones and it should be fine, failing that tap cully up for his mod - a pair of those should get the light out and problem solved Wink
[Image: siggy1.jpg]
#39
thanks will do, just so i am clear do i have to take the driving seat out and take swap the connector about under the seat or is there an easier way? just checked out the drivers seat and it seems a bit tricky to remove.
#40
Well you won't be able to do it with the seat in, so remove it and then it's easy access!
Black mask Service
#41
i changed the seats in my phase 2, for seats from a phase 3, they didnt have the connectors so my airbag light was on all the time. I took the bulb out for MOT and i got an advisory for it not coming on, but didnt fail
Heart 306
#42
Lol one of my mates had a problem with his airbag light on his astra it stayed on and was informed it would be a fail if it didnt turn off so he took off the clocks removed the bulb and connected a bulb to the (i) light cus that goes off after engine is started and passed its mot with that lol
(msg sent from hell)
#43
airbag . . .what airbag? . . . . Angel
#44
Engine management lights are another issue mind.
Apparently it HAS to come on when ignition is turned too, and MUST turn off once the car is started.
Basically its to catch people taking bulbs out...
Supercharged GTi6 Build
S14 Zenki Build
[Image: signature.png]
#45
Niall, what resistors did you use to remove the seat airbags from the equation?
[Image: wallye-gtd.JPG?raw=1]
HDi Owner for 200k/9 years
#46
whistle
http://www.ebay.co.uk/itm/290954729451
#47
(22-08-2013, 04:32 PM)cully Wrote: whistle
Money in the side eh cully Wink
[Image: siggy1.jpg]
#48
Just order a few of those resistors, hopin they actually work. Wink
#49
(08-09-2013, 03:49 PM)KrisCampbell Wrote: Just order a few of those resistors, hopin they actually work. Wink
i best pack them up and go to the post office tomorrow then Wink
#50
Selling many of these then cully ??
[Image: siggy1.jpg]
#51
1 or 2 but its been quiet this week Big Grin
#52
Not mot month then lol
[Image: siggy1.jpg]
#53
Cully, is the one you've linked to for use anywhere on a HDi? As in pretensioner, or side airbag light, plug in under the seat, or at the ecu in front of the gearstick?
I need to frig my brothers light for MOT before Dec.
#54
(22-09-2013, 08:36 AM)C2K Wrote: Cully, is the one you've linked to for use anywhere on a HDi? As in pretensioner, or side airbag light, plug in under the seat, or at the ecu in front of the gearstick?
yes it will replace any of the bags or pretensioners
it will only work only if you have a working system less bag or belt tensioner it wont magicly fix broken looms duff plug connections or duff airbag ECU's
1.8ohm i have found works on my Ph3 HDI and on a ph2
#55
Thanks, i'll order a set. Can't remember what PP was complaining about when i scanned his car at the time. I might PM you for advice next time I see him.
